Old 12-09-2007, 07:17 PM   #1 (permalink)
"The Gentleman"
vish786's Avatar
Post Painless Headphones
Okey guys i hav a normal headphones bought for 150... but ma ears start paining after some time(~10 minutes), i wanna buy a good headphones which r less effective to ears(main point shouldn't cause any pain), with good sound
Budget 650 - 900
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 12-09-2007, 08:16 PM   #2 (permalink)
slugger's Avatar
Default Re: Painless Headphones
Originally Posted by vish786
Budget 650 - 900
Altec Lansing AHS 502i
i bot 1 4 850 bux 1.5 yr back
no complains @ all
slugger is offline
Old 12-09-2007, 09:15 PM   #3 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: Painless Headphones
no complains @ all
is it painless if used for hours together. ?
how about iball it cost around 650 ??
- Dijkstra
vish786 is offline
Old 12-09-2007, 09:41 PM   #4 (permalink)
slugger's Avatar
CORRECTION
i must have bot it sum 2-2.5 yrs back
its very comfy, with cushioned cans and its passive noise cancellation is also quite good (d maid servent apparently went back home on many occasions when der was no one else cause i dint hear d door bell ring )
it was my only source of sound 4 around 2 years (got ATP3 only a few months back)
i 've used it for around 4 hours w/o break and after dat took only a short break of 5 mins b4 puttin back on 4 another 3-4 hours (saw d matrix trilogy )
never felt anythin
even otherwise it used to stay on my ears for around 2-2.5 hours at a strech without me facing any problem
but ofcourse u must ensure dat d vol is not set to very high, otherwise even a Bose will give u tonnz of pain
dunno much abt iBall's headphones, but with AltecLansing u can rest easy knowing dat u gettin a kik azz product
PS: if u looking for just a headphone den u shud consider Altec Lansing AHP512i
same produce - d mic
slugger is offline
Old 12-09-2007, 09:46 PM   #5 (permalink)
"The Gentleman"
vish786's Avatar
i'm lookin for both mic + headphones, done lookin forward to buy Altec Lansing AHS 502i now.
thanks for info.
- Dijkstra
vish786 is offline
Old 14-09-2007, 12:48 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
bt dont use THEM 4 a long time interval ....... might DAMAGE ur EAR DRUM .... resulting in low hearing .........
... W H O T ...
ax3 is offline
Old 14-09-2007, 01:04 PM   #7 (permalink)
shantanu's Avatar
why not to go for PHILIPS SHP2000 .. its great headphones.. and only for 475/- and beleive me, i have used creative, altec lansing and many others .. but the sound clarity and bass effect is so DEEP and amazing.. and the headphones are ultra lite.. and the design is great with auto adjustable headphone..
here is the link
shantanu is offline
Old 14-09-2007, 01:26 PM   #8 (permalink)
slugger's Avatar
i fu sayin so den they must b gud
but i've always had a bad experiance with Philips product
my first brush was with this Philips Music System that we bot in mid 90s
looked like d command center @ NASA but sounded like a band-walla durin marriages
den sum yrs back when my cousin came over for her studies, she brought her computer with her whihc had a Philips 15" CRT
d dammn monitor needed frequent degaussing, whereas my monitor pladec right next to hers faced no such problems
hopefully they must have tightened their qlty ctr by now
slugger is offline
Old 14-09-2007, 01:29 PM   #9 (permalink)
shantanu's Avatar
for me philips was always good.. my first Music system(power house), and my three headphones.. best one i am usign is this one only.. SHP2000 , man i love the bass effect the deepness is there which i wanted and its value for money...
and many times its luck as i had with Intex and LG.. all products i bought were CRAP, but when my friends or anyone relative bought it, man it works great
shantanu is offline
Old 14-09-2007, 01:31 PM   #10 (permalink)
Sup' dude, Sup'
I believe in Philips. Mine is Philips MMS430 2.1 50w rms speakers and they rock.
Go for either Altec Lansing or Philips (best value for money)
ambandla is offline
Headphones......... please help prathap_lab Reviews 20 07-07-2008 12:07 PM
headphones... ssk_the_gr8 Mobiles and Tablets 2 19-05-2007 04:37 PM
Headphones jack19 Mobiles and Tablets 17 17-02-2007 03:17 AM
headphones within 1k to 1.5k slugger Mobiles and Tablets 6 21-06-2006 04:48 PM
Headphones.. Kniwor QnA (read only) 3 03-10-2005 07:46 PM
