Old 10-09-2007, 11:58 AM   #1 (permalink)
Call me Sumit
esumitkumar's Avatar
Cool 5700 vs N91 ME
hi ya all
which is better for playing games (good keypad) and for gud music ?
Nokia 5700 or N91 ?
also does N91 has a bigger screen than 5700 ?
esumitkumar is offline
Old 10-09-2007, 12:53 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: 5700 vs N91 ME
1.5700
2.5700
3.5700
Pathik is offline
Old 10-09-2007, 12:58 PM   #3 (permalink)
gooby pls
Third Eye's Avatar
5700
Third Eye is online now
Old 10-09-2007, 02:31 PM   #4 (permalink)
Call me Sumit
please answer the q : also does N91 has a bigger screen than 5700 ?
and how is the keypad of 5700 ? does ur thumb hurt after 2 hrs of playing ?
Old 10-09-2007, 02:41 PM   #5 (permalink)
Rockin g33k
dreamcatcher's Avatar
well if u want pure music nirvana then go for the n91..coz when it cums to muzic 5700 is nt up there..i personally have a 5700 and after comparing it with se and other nokia music phns i hav cum to this conclusion
well the screen in 5700 is mst probably bigger than the one in n91
5700 is a 9.2 3rdv smartphn and supports a2dp whereas n91 doesnt..so
keep those in mind and choose..
and the joysticks pathetic but the keypad is good
cheers
My blog-www.rayarunava.com
dreamcatcher is offline
Old 10-09-2007, 02:47 PM   #6 (permalink)
Google Bot
Pathik's Avatar
The keys of 5700 are definitely better than n91.. N91 is a very heavy fone.. Also it has a 256k screen whereas 5700 has a 16m color one.. The screen size of a 5700 is bigger than n91.. It has os9.2 and a2dp and class 32 edge- better again then n91
Pathik is offline
Old 10-09-2007, 02:50 PM   #7 (permalink)
Call me Sumit
thanks amd for ans my qs ..wat does a2dp mean ?
Old 10-09-2007, 02:53 PM   #8 (permalink)
M$™ Certified Spammer
entrana's Avatar
a2dp u can use wireless bluetooth headsets to listen to music
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 10-09-2007, 02:58 PM   #9 (permalink)
Call me Sumit
wow ...wats the current cost of 5700 ? and its memory card
Old 10-09-2007, 04:18 PM   #10 (permalink)
Noobie Pro
alsiladka's Avatar
You want a phone for gaming? How could you even think about N91. Its keys are not easy for fast pressing and hurt with continous use. Also, its joystick is bit sharp.
5700 has bigger screen and a bigger resolution.
5700 should cost you less than 12K, about the memory card, i am not sure.
www.twitter.com/alsiladka
alsiladka is offline
Old 10-09-2007, 10:32 PM   #11 (permalink)
5700 comes with 512MB card for free with its pack. For 1GB you have shell out about Rs.700 or more depending on brand.
Anyone who has never made a mistake has never tried anything new
sandeepk is offline
k790i or 5700? adithya_s Mobiles and Tablets 34 05-09-2007 10:08 AM
N91 4gb/n72/5700 Kaushik Mobiles and Tablets 32 10-08-2007 06:30 PM
XFX 5700 le - Problem help? ganesh_2218 Hardware Q&A 1 09-11-2005 12:54 AM
Wanna know how to convert a 5700 LE into 5700 ultra ? regenade QnA (read only) 6 16-11-2004 11:36 AM
