Old 08-09-2007, 06:52 PM   #1 (permalink)
foreign return(0)
comrade's Avatar
Default Nokia N72 doubt
I bought this fone for 9.6k from wavetelmobiles last friday. Actually it was a last time decision that i switched my mind from buying E50.The phone is looking good and serving all my needs. One of review on net about n72 says symbian 8.1 runs applications intended for both 2nd edition and 3rd edition(9.1?).
I just want to confirm whether i can install the symbian 9.1 apps on n72?
comrade is offline
Old 08-09-2007, 06:59 PM   #2 (permalink)
assasin's Avatar
Default Re: Nokia N72 doubt
u cant run OS9.1 apps on OS8.1 and vice versa.
assasin is offline
Old 08-09-2007, 07:13 PM   #3 (permalink)
foreign return(0)
comrade's Avatar
This was quoted in gsmarena
http://www.gsmarena.com/nokia_n72-review-105p3.php
Nokia N72 runs on Symbian 8.1 with 2.8th edition of the Series 60 user interface. This transitional edition is between the 2.5th and 3rd editions of the UI. It has features from both of them and can be considered as the last rehearsal before the 3rd edition.
comrade is offline
Old 08-09-2007, 07:17 PM   #4 (permalink)
Google Bot
Pathik's Avatar
Yup it has some features similar to os9.1 ie v3 like standby apps and all but it CANT run os9.1 apps..
Pathik is offline
Old 08-09-2007, 09:42 PM   #5 (permalink)
foreign return(0)
comrade's Avatar
what does it mean? will it be possible to run atleast few apps if at all not the all 9.1 apps
comrade is offline
Old 08-09-2007, 09:56 PM   #6 (permalink)
Google Bot
Pathik's Avatar
Nope.. none.. But most of the os9.1 apps have their counter parts for os8.1..
Pathik is offline
Old 08-09-2007, 11:06 PM   #7 (permalink)
Noobie Pro
alsiladka's Avatar
If you read it properly, it just says that it is a transitional edition between 2.5 and 3. No mention about application support. Just a few features which were upgraded later in v3.
And S60v3, broke compatibility with the previous editions. Not a bad choice, but you should have consulted the forum, E50 should have been a arguably better choice.
www.twitter.com/alsiladka
alsiladka is offline
Old 08-09-2007, 11:28 PM   #8 (permalink)
Google Bot
Pathik's Avatar
Well n72 is better than e50 for music and cam and fm but e50 has a better os..
Pathik is offline
Old 08-09-2007, 11:43 PM   #9 (permalink)
foreign return(0)
comrade's Avatar
ya..i know..e50 has got better os..but on the day..the shopkeeper gave me both the fones to have a look..e50 looks very cheap got smaller screen comparitively...the cause for my transition from e50 to n72
comrade is offline
Old 09-09-2007, 11:13 AM   #10 (permalink)
!FREEWARES!
Akshay's Avatar
N72 is ne day bettr den E50... So u made a rite choice
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 09-09-2007, 11:51 AM   #11 (permalink)
Google Bot
Pathik's Avatar
^^ not anyday... read my above post..
Pathik is offline
Old 09-09-2007, 12:16 PM   #12 (permalink)
Noobie Pro
alsiladka's Avatar
E50 has S60v3.
Better security, New API's , Scalable Display, SVG Support, and so much bloody more!!
Old 09-09-2007, 01:15 PM   #13 (permalink)
!FREEWARES!
Akshay's Avatar
Wud stil stick to N72 for its looks, camera n usability n no. of applications available for it. Agree dat E50 is bettr in a few departments but overall N72 wins 4 me.
MBP 13.3";
Akshay is offline
Old 09-09-2007, 01:49 PM   #14 (permalink)
OS 8.1 is far better than OS 9.1 or 9.2!
For most of the applications,you have to get 'Developer's Certificate' from Symbian Signed,which is a horrible experience! Adding pain to it is the certificate will expire in 6 months and you have to renew it.
With so many complications in 9.1,it is better to go ahead with Nokia N72!
REMEMBER! IN A RECENT SURVEY BY A LEADING MOBILE SHOP IN CHENNAI SHOWED "N72" IS THE ONLY PHONE WITH MINIMUM COMPLAINTS! SERVICE DEPT RARELY GETS 'N72' FOR ANY DEFAULT!
Be happy with N72, a great phone at a great price!
Some amazing software like "TimeTool" are available only for OS7 & 8!
So,DON'T WORRY! BE HAPPY!
oval_man is offline
Old 09-09-2007, 02:22 PM   #15 (permalink)
Google Bot
Pathik's Avatar
^^ os9.1 is far more advanced than os8.1..
and the dev cert is just a security feature... it takes just a minute to sign any app..
Pathik is offline
Old 09-09-2007, 11:26 PM   #16 (permalink)
Noobie Pro
alsiladka's Avatar
9.1 is much better, you are getting new and amazing softwares day by day. It has more apis, so it is bound to get better softwares than 8.1.
And the security certificate is the reason there are not viruses on 9.1
Old 10-09-2007, 12:25 AM   #17 (permalink)
assasin's Avatar
after using any OS9.x fone u'll never wanna go back to any older os (OS 8.1,7.1....).the integrated browser of OS9.x fones just rock.i like it better than Opera 8.65.
assasin is offline
Old 10-09-2007, 12:52 AM   #18 (permalink)
deathvirus_me's Avatar
I want to .. i miss apps. like PowerMP3 , a fully workin FE Explorer , and custom extensions ... OS9.1 sucks when it comes to application compatibility .. OS8.1 rockz !!
deathvirus_me is offline
Old 10-09-2007, 12:53 AM   #19 (permalink)
Google Bot
Pathik's Avatar
^^ yup.. And its download manager rocks too..
Btw the release of opera mini 4 betas made the webkit browser a bit insignificant
Pathik is offline
Old 10-09-2007, 02:49 PM   #20 (permalink)
Recent os9.1/9.2 r meant for developers.
End users r benefitted from well studied & experimented os like 7 or 8.1.
ksundar is offline
Old 10-09-2007, 04:32 PM   #21 (permalink)
Noobie Pro
alsiladka's Avatar
Wov!! What an comment. Would you please mind enlightening us by collaborating on your comment? Explaining what it means.
The OS 9.x has been specefically created to provide an advanced and secure OS to the customers. How come meant for developers fits in?
The sighed application feature is excellant, abeit not implemented properly. Not giving the application auto start and automated rights unless it is signed has virtually minimized the threats viruses can pose.
All my OS 7 and 8 friends are scared to use their phones without anti virus, which i believe would be the case with you too.
OS 9 is an improvement over 7 and 8, except for features like Coloured Logo changing (which is not yet changable manually like previous os, you can use black and white logos though), no other feature hampers the users experience in any ways.
For all those who say they cannot access the Sys and Private folder, i do not see any reason for you to be able to do so. You can access the Mail folders using Y-Browsers. Please remove my lack of knowledge for any other purpose of the Sys and Private folders access to the end user.
Old 11-09-2007, 08:49 PM   #22 (permalink)
foreign return(0)
comrade's Avatar
windows vista doesnt do anything great..and most of us can live with xp itself.....
like that will 9.1 be a revolutionaly os for mobile phones ..or it will just be an another update?
comrade is offline
Old 11-09-2007, 09:36 PM   #23 (permalink)
Noobie Pro
alsiladka's Avatar
It is a revolutionary update. It breaks all compatibility with the previous editions.
The software which worked on the previous editions, will not work on OS 9.1 (S60v3). It shall have to recoded for 9.1
Probably the biggest change in the eye of the consumer is the break in binary compatibility. This means that programs written in C++ for previous versions of Symbian OS will not run on OS 9 without the original authors making a few changes to the source code and recompiling.
It brings in awsome features like SVG Support, Scalable APIs (try out the RotateMe app), and many new APIs. It supports FOTA.
Check out this article on AAS.
Many things have come to light after this article.
Small doubt regarding my Nokia 6020 purifier Mobiles and Tablets 8 18-03-2006 06:17 PM
