Old 07-09-2007, 11:28 PM   #1 (permalink)
Default how to charge ipod????
A frnd of mine got a year old ipod nano 4gb frm a cousin in us...
which has been used for an year with itunes.......
i plugged it into my computer(usb 1.0) now it works when its connected to the computer ...it shows a charging sign.....as soon as i disconnect it ....a apple logo appears and nothing works.....i waited for an hour before disconnecting...
I didnt used itunes ....i used anapod to transfer 3 songs....can this be a problem?????
hpindia is offline
Old 07-09-2007, 11:42 PM   #2 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: how to charge ipod????
well anapod shouldnt be a prbolem ... wat os are u using ... a similar problem wa faced by many using the earlier versions of vista ... and do a complete reset using itunes ....
http://beingmanan.com
iMav is offline
Old 08-09-2007, 06:33 AM   #3 (permalink)
Boom Boom Boom
cooldudie3's Avatar
try resetting it might help on itunes press ur ipod's name and then press reset
I'm back! Gimme a hugggggg... :D
cooldudie3 is offline
Old 09-09-2007, 02:26 PM   #4 (permalink)
aryayush's Avatar
Isn't the USB 1.1 a problem?
aryayush is offline
Old 10-09-2007, 11:12 AM   #5 (permalink)
Mr. S Nova
supernova's Avatar
Nah.. i dont think so..
a friend of mine faced a similar problem but it was solved after a reset..
Knock Knock. Who's there? Opportunity. Can't be, opportunity knocks only once...
supernova is offline
Old 10-09-2007, 01:19 PM   #6 (permalink)
thnx i will try it out....
hpindia is offline
Old 12-09-2007, 08:06 PM   #7 (permalink)
busyanuj's Avatar
try restarting your iPod by pressing "menu" and the centre button together for a few seconds.
busyanuj is offline
How 2 charge your phone dialing a 3 digit no.?? ratedrsuperstar Mobiles and Tablets 17 25-06-2007 06:20 PM
