Try it
start menu>ctrl panel>Phone and modem>Modems>add>dont detect my modem......(check)>nokia>in models select ur phone model (bluetooth)and next
it add ur nokia modem
Now go to
start menu>ctrl panel>Network setting>create a new connection>new connection wizard>connect to the internet>set up my connection manualy>connect using dial up modem>select ur bluetooth modem(check)>isp name (airtel or watever u want)>phone number(*99***1#)or (*99#)>user name and pass (blank)>add shortcut to.....(check)>finish
now first detect ur cell from bluetooth
then pair them
and click on the short cut which u made on desktop say airtel
and in some sec u r ready with net
Originally Posted by JohnephSi
I connect mobile office using my bluetooth's inbuilt modem not through my nokia usb modem. when i connect through usb data cable it connects using my inbuilt fon modem.i used version 6.83.and bluetooth version 2
seems u are u using ivt bluesoleil
anyway try wat i said
whats ivt version... is it 1.6xx ????????
