30-08-2007, 09:37 AM
666
NOKIA 6630 with 1Gb MMC
I want to upgrade my existing 256 Mb MMC with a higher capacity card.
which one will be better, 512Mb or 1Gb?
please advice.. thanx in advance..
(users of 6630)
MSI-P35-NEO| C2D-E7300 | XV-9600GT | WD-640 | LEADTEK-DTV-1800H | CORSAIR-TWIN2X2048-6400C4DHX | ZEBRONICS-PRO M500W | SONY-DRU-V200S | LOGITECH-X90 CORDLESS
30-08-2007, 09:46 AM
in search of myself
Re: NOKIA 6630 with 1Gb MMC
Its good that u wana upgrade but why same post in two different sections. You can be banned for this. Mods close this thread under hardware troubleshooting
http://www.thinkdigit.com/forum/show...624#post589624
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
30-08-2007, 09:57 AM
666
yes.. i have already asked to close that thread.. by mistake i clicked the wrong link...
any suggestions on the MMC?
30-08-2007, 10:33 AM
!FREEWARES!
U can update ur firmware n use 1GB card safely. Else go 4 512MB
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
30-08-2007, 10:49 AM
Wire muncher!
i'd suggest 512mb too. don't put in 1GB unless you frequently do the housekeeping chores. it becomes dead slow when the card is about 6-700 mb full. but then it mebbe jus my experience (actually not mine, but my fren's)
30-08-2007, 10:54 AM
I've been running my 6630 with 1GB for quite sum time now (Kingston 1G for 1000 bucks with lifetime replacement warrantee). Just make sure that u dun have unwanted apps running in the BG. Rest said, 1gb will not be a pain for 6630.
30-08-2007, 11:20 AM
Pee into the Wind...
The max. memory 6630 can support is 2gb.So 1 gb would be fine.I have been using it for abbout a year upto 900 mb full without problems.
Life is as complicated as you say it is.
30-08-2007, 11:26 AM
666
My firmware version is 6.03.08 dated 13-02-06
bro.. can you please explain what does life time replacement warranty means. because i heard some sellers cheat using that jargon.
Reason: Automerged Doublepost
30-08-2007, 11:37 AM
Wire muncher!
well lifetime in these products is usually 3 or 5 years.. thats coz everyone things that after this duration the product is obsolete and not in use anymore.
30-08-2007, 02:24 PM
666
thanks guys! bought 1Gb MMC. started to install my apps. MODS please close this thread.
30-08-2007, 08:30 PM
!FREEWARES!
@solomon
Chk if updates r available 4 ur cell at europe.nokia.com.
MBP 13.3";
31-08-2007, 09:52 AM
666
Nice info
@solomon
thanks pal...
