Old 17-08-2007, 09:55 PM   #1 (permalink)
Still learning...
He28's Avatar
Unhappy Memory Card Damaged...
Hi all,
I am sure you guys will help me out.
I have Nokia 3230 with 256 Mb Memory card. I few days ago I was transferring some pics from card to computer using USB card reader. After the transfer I accidently did a Windows QuickFormat of that Memory Card. Now, when I insert the card in my cellphone and try to access it via phone, my Nokia shows the card damaged and asks to format it.
Now I can not access my card and also I am unable to format it using my cellphone... as when I try to format it, the process goes for about 10% and hangs there.
Guys, please help me with your expert suggestions and let me know that how can I format the card again so that it may be used by my Nokia 3230.
Thanks.
People laugh at me because I am different...,
I laugh at them because they all are the same...
This is... attitude!
He28 is offline
Old 17-08-2007, 10:00 PM   #2 (permalink)
Default Re: Memory Card Damaged...
Is the card working with PC? If yes try a full formatting there. Card formatted in other phones /pc are not fully compatible in phones. Format ur card only using the device you want to use it most.
ThinkFree is offline
Old 17-08-2007, 10:15 PM   #3 (permalink)
Pee into the Wind...
shady_inc's Avatar
try formatting the card in other series 60 fone.i fail to understand how quickformatting ended up damaging ur card.Did u end up changing the disk type too...accidentally??
Life is as complicated as you say it is.
shady_inc is offline
Old 18-08-2007, 12:09 PM   #4 (permalink)
Web Design Hobbyist
Try to format it again using the card reader in windows and select the following formatting options:
File System: FAT
Allocation Unit: Default
Then insert into the fone and try to format it there.it should work .Otherwise, try to format using another S60 device as told to u in the earlier posts.
Neel Kamal Kalita
Web: http://neelsworld.in
dreamzchm is offline
Old 18-08-2007, 07:29 PM   #5 (permalink)
Still learning...
He28's Avatar
Thanks dreamzchm
Your suggestion helped. Did a FAT format and everything is fine now.
Thanks again.
He28 is offline
Want to store messages in memory card or phone memory(Motorazr V3i) thetopcyborg Mobiles and Tablets 2 01-12-2006 01:45 PM
is my agp card damaged ? !!! bkpeerless QnA (read only) 4 02-09-2006 04:43 PM
Copy messages from phone memory to memory card Aparajith Mobiles and Tablets 2 17-02-2006 10:12 PM
Copy Sms from Phone Memory to Memory Card mako_123 Mobiles and Tablets 4 02-12-2005 08:17 PM
Memory card? Multimedia Card? Memory Stick?.....confused linardni QnA (read only) 8 07-09-2005 12:09 PM
