Old 11-08-2007, 04:38 PM   #1 (permalink)
Norms Buster
Lightbulb PCMCIA card or USB Modem for Reliance Netconnect ?
For the Reliance Netconnect; which is the better option for Laptop, PCMCIA card or USB Modem ?
http://www.reliancecommunications.co...etconnect.html
VexByte is offline
Old 11-08-2007, 07:43 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: PCMCIA card or USB Modem for Reliance Netconnect ?
Get a USB modem... U can use it in ur pc too..
Pathik is offline
Old 12-08-2007, 03:19 PM   #3 (permalink)
l[/URL]
USB modem, but why are you going for Reliance. Most probably you wud be repenting after buying it as they don't provide good service. Go for TATA Indicom in CDMA or Airtel for GSM connection(lesser speed than CDMA, but greater coverage)
ThinkFree is offline
Old 14-08-2007, 05:05 PM   #4 (permalink)
Norms Buster
So is it better to use the EDGE/GPRS of Airtel than the Reliance Netconnect ?
VexByte is offline
Old 15-08-2007, 12:29 AM   #5 (permalink)
Yep go for it if it is available at your place. Don't expect blazing speed without EDGE. Do check with airtel about availability of EDGE before you make any decision. W/o EDGE speed will be max 7-8KBps
Anyone who has never made a mistake has never tried anything new
sandeepk is offline
Old 15-08-2007, 11:13 AM   #6 (permalink)
Though speed available on GSM network would be a little less than CDMA(Tata/Reliance) but as per my experience you should not be going for Reliance,there voice services are far from satisfactory and forget about data. The best option is Airtel as it is having the best network in the country
Old 18-08-2007, 11:50 AM   #7 (permalink)
Techans
nikhilpai's Avatar
Does any operator in India provide Expresscard net connections (instead of USB or PCMCIA)
If not does anyone plan to introduce it soon?
nikhilpai is offline
Old 18-08-2007, 12:01 PM   #8 (permalink)
Wire muncher!
infra_red_dude's Avatar
i don't think any operator is providing expresscard here in india. i haf seen none till date.
infra_red_dude is online now
Old 19-08-2007, 12:01 PM   #9 (permalink)
Troubleshooter
Best go for the new USB Plug2Surf by Tata Indicom. My friend is using in Bangalore and he says the speed is amazing for a wireless connection. He says my Airtel sucks.
deepakchan is offline
Any Reliance Netconnect user? Anindya Chit-Chat 12 21-01-2008 07:07 PM
Y! Messenger disconnects frequently on Reliance Netconnect iinfi Mobiles and Tablets 18 20-02-2007 12:51 AM
Reliance R-Connect PCMCIA Card - Requesting Review nebeldunkel QnA (read only) 2 18-06-2005 02:00 AM
