Old 11-08-2007, 12:53 AM   #1 (permalink)
Jack Sparrow
joey_182's Avatar
Question Nokia phones as USB pen Drive??
guys i want to use my nokia phone as USB pendrive...(N72)
so if u know any application exist, which can be installed on phone to make it use like pen drives....
and do u think..this thing depends on memory card also...??
(motorola razer can be used as pen drive,so y not nokia n series)
KHAO PIYO TE AISH KRO!!
http://twitter.com/puneetshrma
joey_182 is offline
Old 11-08-2007, 12:54 AM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: Nokia phones as USB pen Drive??
i don't think you need any apps for that. i guess only the relevant mass storage driver provided on the disk. simply insert it and connect the phone. it'll ask for the drivers if i'm rite. point to the cd and let it install. you should be able to see it in my computer (in windows) Quiz master can help you more on this.
infra_red_dude is online now
Old 11-08-2007, 08:35 AM   #3 (permalink)
harryneopotter's Avatar
Dnt knw about N72, but my 5200 can be used as a pendrive without installing any drivers.
Just connect the usb cable and it will ask for connection mode and then choose DATA & STORAGE MODE ..... and it will show as a removable drive in my computer. But u can only acces the Memory card ...not the phone memory ........
harryneopotter is offline
Old 11-08-2007, 08:56 AM   #4 (permalink)
Google Bot
Pathik's Avatar
yup.. U dont need ny drivers for this.. Jus plug in the cable and select the data storage/transfer mode.
Pathik is offline
Old 11-08-2007, 09:44 AM   #5 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
I have N72.
Well, N72 can be used to transfer data from one place to another, but I won't say it exactly work like a pen drive.
For first every time you connect it to a new PC, you will need to install drivers for it. And Nokia PC Suite too(Optional). For that you always have to keep driver CD with you.
There isn't any other short way. Installation of drivers is necessary.
Application on a phone to do this is not possible..because its your PC that must be able to detect your Mobile.
You can do what I did...
I installed Nokia Drivers and PC Suite in computers of my every friend, (They are allready installed in my college.)
So whenever I need to transfer data I have to just plug my mobile.
What my another friend did is, He bought a Card Reader..(150 rupees), and whenever he need to transfer data he take out his memory card, insert it in card reader, and use card reader as a Pen Drive.
Offtopic : Recently I got a chance of testing N70ME and 5500. N70 was a dazzling new phone. But when I tested it, I found it slower then my N72. Strange.
But 5500 was cool looking and fast. Really liked it. Yet to test 5700.
Quiz_Master is offline
Old 11-08-2007, 10:27 AM   #6 (permalink)
Noobie Pro
alsiladka's Avatar
I am not sure about N72, but all the S60v3 phones can be used as a Removal Storage ( Pen Drive) without the need for PC Suite.
Simply plug in the USB cable, and when the phone displays the mode selection choice, select Mass Storage.
www.twitter.com/alsiladka
alsiladka is offline
Old 11-08-2007, 11:15 AM   #7 (permalink)
Google Bot
Pathik's Avatar
yup.. afaik n72 also has the removable storage option...
and the data transfer rate in it is much higher than the pc suite mode..
Pathik is offline
Old 11-08-2007, 11:22 AM   #8 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Thanks bro, didnt knew that. Now my 2GB card will come in handy and MicroSD is so small, can easily fit in my Wallet...the extra 512 will also come in handy
Thanks again
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 11-08-2007, 11:02 PM   #9 (permalink)
* Teh Flirt King *
No It doesn't.
I have it. And I checked it with every possible way.
Connect it without installing drivers.. It says that device attached to USB port is unknown.
Only way is PC Suite or similar softwares.
Old 11-08-2007, 11:09 PM   #10 (permalink)
krazyfrog
Posts: n/a
Yup older S60 phones like N72 didn't support USB mass storage. Its only from S60 v3 that mass storage support was added.
Old 11-08-2007, 11:12 PM   #11 (permalink)
Rebooting
Choto Cheeta's Avatar
Once again I poke my nose in sorry to ask, whats the price of 2GB Memory card ??
I am not too sure, but asked some one in my yahoo messenger list, and I was told around Rs. 1500/- so, as Quiz_Master said, Rs. 200 for a Card reader, and one 2 GB Card Rs. 1500 so ttal 1700/-
so once again, I press for the Home Made Palm Driver instade of a option like this, read in this thread please...
Rs 2000 for which pen drive ?
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 11-08-2007, 11:17 PM   #12 (permalink)
cant say bout S60, but my S40 5200 supports the removable drive feature.
2 GB MicroSd card costs around 1100-1200 ..........
Last edited by harryneopotter; 11-08-2007 at 11:17 PM. Reason: Automerged Doublepost
Old 12-08-2007, 12:25 AM   #13 (permalink)
Google Bot
Pathik's Avatar
yup.. 2gb fake transcend and kingston cost arnd 1k.. I m using my 1gb micros d as a pendrive since quite some time..
Pathik is offline
Old 12-08-2007, 01:09 AM   #14 (permalink)
Jack Sparrow
joey_182's Avatar
ok...so can it be upgraded to S60v3...i know it cant be upgraded to full S60v3 but y not just application..for memory card to read as pen drive...i think it can be yaar....?programmers can do this...
joey_182 is offline
Old 12-08-2007, 08:24 AM   #15 (permalink)
Wire muncher!
that thing can't be got to work by installing some app on the phone or computer. what we need to do it include that option of identifying as mass storage in the firmware of the phone. so unless nokia release a new firmware wid this feature built in you can't do much.
Old 12-08-2007, 12:18 PM   #16 (permalink)
Host4Cheap.org
I can help since i bought one last week, MicroSD 2GB
Transcend - 1200
Kingston - 1300
Sandisk - 1300
Old 12-08-2007, 12:24 PM   #17 (permalink)
Rebooting
Thnx for the Info, so any comment here, Rs 2000 for which pen drive ? on the Mentioned topic of 2 gb for Rs. 1300 vs 80 gb for Rs. 2500 ??
rebooting
ChotoCheeta.com
Old 12-08-2007, 12:31 PM   #18 (permalink)
Host4Cheap.org
ADDED a comment
Old 12-08-2007, 08:53 PM   #19 (permalink)
Jack Sparrow
joey_182's Avatar
@infra_red_dude
ya thats y waiting for very good fimware of N72...
joey_182 is offline
Old 12-08-2007, 09:50 PM   #20 (permalink)
Google Bot
Pathik's Avatar
^^ dont expect any extra feature like data storage mode in the new firmware of n72..
Pathik is offline
Old 12-08-2007, 10:05 PM   #21 (permalink)
Jack Sparrow
joey_182's Avatar
ya..that ll be too much...
joey_182 is offline
Operator logo for nokia phones ThinkFree Mobiles and Tablets 4 21-04-2007 03:17 AM
Nokia Phones Nomenclature a_to_z123 Mobiles and Tablets 8 20-07-2006 10:20 PM
New phones from SE and Nokia gdatuk Buying Advice 14 29-06-2006 10:56 AM
New Phones From Nokia and Sony Ericsson devilhead_satish QnA (read only) 2 14-06-2005 06:11 PM
