Old 05-08-2007, 09:41 AM   #1 (permalink)
Can you hear it..??
windchimes's Avatar
Default blutooth or datable to use with mob for net connn
hi guys,
got a new Nok-6233 . Now i am interested in connecting to internet using this set.Should I use a data cable or a Blue tooth USB adapter (dongle..rt?) for the purpose. The ppl in the shop suggested to use bluetooth adapter and I purchased it , but few guys now tell me that data cable gives better speed. Plzzz help. (And how much a datacable costs..?? are they specific to models or brands ) .thanking you.
regards
Windchimes
windchimes is offline
Old 05-08-2007, 09:57 AM   #2 (permalink)
Default Re: blutooth or datable to use with mob for net connn
Use data cable as it would give you better speed and would consume less battery.
ThinkFree is offline
Old 05-08-2007, 11:03 AM   #3 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
^^+1 to that
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 05-08-2007, 11:20 AM   #4 (permalink)
Google Bot
Pathik's Avatar
Yup ... get a data cable... but afaik its bundled wit a 6233...
Pathik is offline
Old 07-08-2007, 04:42 PM   #5 (permalink)
chinmay's Avatar
I have seen a definite speed difference between data cable and Bluetooth while using internet through E-GPRS. I'd suggest you to go for data cable.Although the transfer speed offered by most Bluetooth dongles is much higher than maximum speed supported in a GPRS connection, it lags the already slow internet speed offered by most Indian Mobile service providers.
I Blog at - http://www.chinmayspeaks.com
chinmay is offline
Old 07-08-2007, 05:05 PM   #6 (permalink)
Back in Power
almighty's Avatar
DATA CABLE , if u can buy original then it wud be better for u coz local made cable sometime wont work and not compitable with many cell phones
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
Suggest me edge + blutooth enabled cell up to 4000 mkmkmk Buying Advice 11 25-08-2006 09:12 PM
send any file through blutooth or irda sanyaldk Mobiles and Tablets 11 04-08-2006 08:25 PM
blutooth file transfer software nithun Mobiles and Tablets 2 24-06-2006 01:29 AM
cheapest nokia with blutooth,java , computer interface port? harmax Mobiles and Tablets 5 12-07-2005 11:08 AM
