Old 04-08-2007, 04:16 PM   #1 (permalink)
Exclamation help me......with my e-250
Guys I have just baught a new samsung e-250
but i cannot been able to install java applications & games on it
wat is the procedure for it
when i downlaod any application or game then after downlaoding it automatically starts installing...........
what do i do???
how do i install apps & games
i have mobile, bluetooth dongle....,
please its important for me..............
prateek57 is offline
Old 04-08-2007, 06:58 PM   #2 (permalink)
respect mah authoritah!!
girish.g's Avatar
Default Re: help me......with my e-250
my friend has the same prob. first make sure you hav downloaded games in .jad format then transfer it to your phone and then open it
girish.g is offline
Old 04-08-2007, 08:01 PM   #3 (permalink)
a_k_s_h_a_y's Avatar
its actuallly .jar that matter
if .jar fails to install..then download both .jar and .jad and try to install
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is online now
Old 04-08-2007, 09:14 PM   #4 (permalink)
Google Bot
Pathik's Avatar
if u use the jad file to install then u ll need to have a working gprs connection.. if u want an offline install then use the jar file only.. either dload it or trnsfer thru data cable or bt..
Pathik is offline
Old 05-08-2007, 07:29 PM   #5 (permalink)
girish.g's Avatar
hey jar files come in the other folder where you can either delete them or send it to anyone else thats it.
you need jad files for e250
girish.g is offline
Old 06-08-2007, 04:42 PM   #6 (permalink)
Exclamation Re: help me......with my e-250
guys now i dont have a working gprs on my phone
but
i have some .jar & .jad files on my system as well as on my memory card
i want to know how do i install them on my phone as there is option as "install" in the file option menu
there is only send, move, delete & so on.........
Old 09-08-2007, 04:29 PM   #7 (permalink)
guys please reply its important for me
