Old 04-08-2007, 02:27 PM   #1 (permalink)
Mobile Freak
reddick's Avatar
Exclamation Updating FirmWare of 'Nokia 2610'
Hi All!
I have this phone frm last one year n now planning to update it's FirmWare.So guys tell me which Data Cable needed for it? I have PC Suite n NSU installed in my PC One more thing,I visit nokia.com/softwareupdate n whn I input product code of phone,it says their is no update available for this model But I don't trust on it. So I planned it connect it with PC n checks via NSU whether I can update it or not Recently d FW is 03.77 Did anyone has any ideas THANKS A LOT!
reddick is offline
Old 04-08-2007, 06:19 PM   #2 (permalink)
Default Re: Updating FirmWare of 'Nokia 2610'
I don't think that Nokia 2610 firmware can be updated by the user himself. THIS FEATURE is being made available in new phones only. You will have to go to nokia care centre
ThinkFree is offline
Old 04-08-2007, 06:32 PM   #3 (permalink)
Cool G5's Avatar
Post Re: Updating FirmWare of 'Nokia 2610'
You have to take it to Nokia care.
There is no data cable for it.
Cool G5 is offline
Old 05-08-2007, 08:25 AM   #4 (permalink)
Mobile Freak
reddick's Avatar
NO! there is an data cable for it.I searched eBay n found CA-45 cable of it.I even placed d order n gona gt it within 2-3 days Gona tell u d results soon
reddick is offline
Old 05-08-2007, 10:50 AM   #5 (permalink)
Wandering in time...
Ankur Gupta's Avatar
Even if you manage to connect the phone to your PC successfully you still wont be able to update the firmware as it is not available on NSU..
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 06-08-2007, 01:23 PM   #6 (permalink)
Mobile Freak
reddick's Avatar
How do u know that it is not available @ NSU
One more thing,Can v FORMAT this phone If yes,then HOW
reddick is offline
Old 06-08-2007, 03:37 PM   #7 (permalink)
krazyfrog
Posts: n/a
1. You cannot update the firmware of this phone. Only service centre guys can. Moreover i seriously don't think there are any firmwares for this phone to update to.
2. You cannot format this phone.
3. Your money on the data cable is as good as been wasted. Next time you feel like blowing up your money, give them to me instead.
Old 06-08-2007, 06:34 PM   #8 (permalink)
You can restore the phone settings to that which were set when the phone was manufacture by using RESET PHONE SETTINGS in tools menu (must be in phone settings). All the data that you put in the phone would be lost after that
Old 06-08-2007, 07:43 PM   #9 (permalink)
krazyfrog
Posts: n/a
^^ None of the data will be deleted. Only the settings will be restored to factory settings.
Old 06-08-2007, 09:26 PM   #10 (permalink)
^^The messages/ringtones get deleted...Also if the contacts are stored in phone memory they too get deleted...
Old 06-08-2007, 10:52 PM   #11 (permalink)
krazyfrog
Posts: n/a
Nope. That happens in SE phones, not in Nokia phones. The default reset option in Nokia phones only reverts the settings back to their default values. Data like contacts, messages, calendar entries and other such data do not get deleted. However in the cheaper Nokia phones with Composer, the tones in Composer do get deleted.
Old 06-08-2007, 10:58 PM   #12 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Smile Re: Updating FirmWare of 'Nokia 2610'
no re it happens in nokia phones also...specially the lower models!!
Wadadadada!! ??
Ambar is offline
Old 07-08-2007, 05:56 PM   #13 (permalink)
^^yes exactly...
@krazyfrog
Maybe you have used too many high end phones
Old 07-08-2007, 06:53 PM   #14 (permalink)
Boom Boom Boom
cooldudie3's Avatar
forget it!!!!!
it won't work
money wasted
update in the care center
I'm back! Gimme a hugggggg... :D
cooldudie3 is offline
Old 07-08-2007, 07:02 PM   #15 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
nahi be i have read it on the net..tht its psible to upgrade firmware urself....but its voids the warranty....eill get back soon
Wadadadada!! ??
Ambar is offline
Old 07-08-2007, 08:54 PM   #16 (permalink)
sauravktr's Avatar
Abe... yaar tune sahi kaha ki it is posible to upgrade firmware urself....but not with this models.....phones comes with SYMBIAN Os like nokia 6680,6681,n72,n73....Is type ke phon ko DKU-2/ca-42 cable se Online firmware update kar sakte hai....
For nokia 2610 u can update the firmware if u have the UFS/AJF flashing kit in ur home....serach google for more of it...This flashing kits are coming with 60-70 special types of data cables....and latest firmwares are available in their sites.....u can download them...
" 99% computer Problems are between the PC & the CHAIR "
sauravktr is offline
Old 07-08-2007, 11:17 PM   #17 (permalink)
^^us kit ko kharidne me to naya Nokia 2610 aa jayega...lol
Anyway thanx for the info...didnt have any clue about it...
Old 08-08-2007, 06:03 AM   #18 (permalink)
krazyfrog
Posts: n/a
I used the older Nokia low-end phones a lot and frequently reset them. But i've not yet reset one of the newer ones. But i'm pretty sure that i'm right. In S40 phones reset does not clear data, only reverts the settings back to default settings. A good way to check this is to go to the reset option in Settings and wait for some time for the help text to appear on screen. Or to read the manual. Both will say that no data is deleted.
Old 08-08-2007, 10:22 AM   #19 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Wink Re: Updating FirmWare of 'Nokia 2610'
egxactly........mate..thts wht i was saying
Wadadadada!! ??
Ambar is offline
Old 09-08-2007, 10:08 AM   #20 (permalink)
Boom Boom Boom
cooldudie3's Avatar
2610 cannot update firmware!
ONLY IN CARE CENTER!
urrrr......
Updating the firmware of MP3 player -- is it safe? nithinks Software Q&A 5 21-12-2006 11:48 AM
How to Update Nokia 6630 firmware assasin Mobiles and Tablets 2 06-11-2006 02:00 PM
Nokia N70 Problem after Updatin FIRMWARE pra_2006 Buying Advice 5 02-11-2006 02:29 AM
Latest Nokia Firmware Revisions g_goyal2000 Mobiles and Tablets 8 20-09-2006 06:52 PM
Nokia firmware Pathik Mobiles and Tablets 2 15-03-2006 07:30 PM
