Old 03-08-2007, 09:39 AM   #1 (permalink)
Default Connecting two nokia phones on same computer
Tell how to use two different nokia phones with pc suite(same version). I earlier installed pc suite for use with nokia 7610 and it worked but when I try to connect it with Nokia 6020 after installing drivers, windows give a USB device malfunction message. After that if I connect nokia 7610, windows install drivers for that once again .Help!!
ThinkFree is offline
Old 03-08-2007, 10:24 AM   #2 (permalink)
Back in Power
almighty's Avatar
Default Re: Connecting two nokia phones on same computer
use 6.83 nokia pc suite
u don ve to install driver seprately, it seems u ve original data cable coz 7610 comes with data cable...
but my dear frnd AFAIK 6020 need ca 42
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
Old 04-08-2007, 09:46 AM   #3 (permalink)
No, same cables can work
Also, headset provided with one phone works with other without any problem
Old 07-08-2007, 06:49 PM   #4 (permalink)
Boom Boom Boom
cooldudie3's Avatar
try the newest pc suite version
I'm back! Gimme a hugggggg... :D
cooldudie3 is offline
N70 not connecting to computer jughead Mobiles and Tablets 8 15-03-2007 07:53 PM
do we need hub when connecting 2 computer by lan digiFriend Software Q&A 5 31-03-2006 12:59 AM
connecting TV with computer using agp card thadhanihemant QnA (read only) 9 11-01-2006 03:07 PM
Connecting TV to computer naveenpoddar QnA (read only) 17 02-05-2005 03:04 PM
