LinkBack (2) Thread Tools Display Modes
Old 02-08-2007, 12:56 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Unhappy How to remove FAX RECEIVED icon from my LG KG300 Mobile phone?
I always surf net through my cell only.After surfing morning,i sent a sms to airtel to deactivate gprs..When sms sent a new message opened by default showing NEW FAX.Only back button was working & i pressed it.Now i dont understand that how can i receive fax in cell..Cause there is no option in phone.Also FAX RECEIVED icon is irritating me on the cell screen along with network indicator.. What to do please help to remove icon..
deepakg is offline
Old 06-08-2007, 06:47 PM   #2 (permalink)
Default Re: How to remove FAX RECEIVED icon from my LG KG300 Mobile phone?
This is virus I hope. Even its troubling me in LG KG 200 model.
srikanthmx is offline
Old 06-08-2007, 06:51 PM   #3 (permalink)
Try resetting phone settings to defaults
ThinkFree is offline
Old 06-08-2007, 06:53 PM   #4 (permalink)
AJJU
azzu's Avatar
theres no virus for the samsung LG KG 200 model in my view
I love and Live to Design
azzu is online now
Old 26-01-2008, 02:59 AM   #5 (permalink)
have you considered doing a hard reset? or maybe a firmware update? you can firmware here http://www.timtechs.com/unlocked-lg-...te-prd134.html
mickeytwist is offline
Old 26-01-2008, 07:48 AM   #6 (permalink)
Boom Boom Boom
cooldudie3's Avatar
That is just crazy! Try reseting the phone and try the firmware update
I'm back! Gimme a hugggggg... :D
cooldudie3 is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/64488-how-remove-fax-received-icon-my-lg-kg300-mobile-phone.html
Thread LG KG200 n KG300 | Digit Forum | BoardReader This thread Refback 31-03-2011 03:11 PM
Thread lg kg300 phone lock | GSM-Forum by zfrank | BoardReader This thread Refback 10-08-2010 07:59 PM
how to remove defender icon in vista mohitgiri Software Q&A 3 26-07-2007 08:06 PM
New Mobile Phone ??? vineetrocks2005 Buying Advice 4 02-04-2007 03:35 PM
LG KG200 n KG300 sandeepkochhar Mobiles and Tablets 2 13-11-2006 01:54 PM
best mobile phone to buy arunks Buying Advice 4 07-10-2006 03:03 AM
