Old 24-07-2007, 07:07 AM   #1 (permalink)
Norms Buster
Arrow Diff. b/w Original Nokia & Unbranded Data Cable
One of my friends needs a Data cable to connect his PC/laptop to the Nokia 6080 for the EDGE functionality. The original Nokia Data cable CA-42 costs about Rs.1600-1800 while the unbranded ones are costing about Rs.500-600.
Will an unbranded data cable cause any damages to the computer and the cellphone ?
Is there any other hidden dangers in using unbranded ones ?
VexByte is offline
Old 24-07-2007, 08:05 AM   #2 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: Diff. b/w Original Nokia & Unbranded Data Cable
No problemo!
Nokia N86 8MP
Lucky_star is offline
Old 24-07-2007, 09:10 AM   #3 (permalink)
Though it may not be causing much problem to hardware but you won't be getting the performance as with original one
ThinkFree is offline
Old 24-07-2007, 10:03 AM   #4 (permalink)
Google Bot
Pathik's Avatar
asta lavista baby..
Pathik is offline
Old 25-07-2007, 07:25 AM   #5 (permalink)
Norms Buster
How can I distinguish b/w Original Nokia & Unbranded Data Cable ?
VexByte is offline
Old 25-07-2007, 07:58 AM   #6 (permalink)
You are paying Rs.500 for an unbranded data cable? It seems too expensive. My friend bought one for around 250 bucks. I'm not sure.
Well, I don't think there is any difference between the two, but you may loose the warranty if you use the unbranded one, get some problem and nokia people come to know of it.
prashanthnbhat is offline
Old 25-07-2007, 10:36 AM   #7 (permalink)
Wire muncher!
infra_red_dude's Avatar
do not worry abt anything. the compatible ones retail for less than 300 now. get one of them. its totally harmless. u may safely use it.
infra_red_dude is offline
Old 25-07-2007, 12:47 PM   #8 (permalink)
Sup' dude, Sup'
I have been using the USB to mini-USB data cable for nokia 6300. Got it for Rs.100 and no issues.
ambandla is offline
Old 25-07-2007, 04:36 PM   #9 (permalink)
wAnnaBe pIraTe
munchy's Avatar
dude if ur in bangalore,
go2 national market in majestic and bargain,
u'll get one for <300rs
and yeah the fake ones hav no drwback and are safe,
if u find on the net,
thy are built using the same architecture as the original ones,
"EVERYTHING IS POSSIBLE,
THE IMPOSSIBLE ONLY TAKES LONGER."
munchy is offline
Old 25-07-2007, 04:53 PM   #10 (permalink)
Learner
Kniwor's Avatar
Please explain.
IMHO, there's nothing to worry about, they're all the same, the original will just look more flashy.
Kniwor is offline
Old 25-07-2007, 05:11 PM   #11 (permalink)
King of my own Castle
freshseasons's Avatar
Hmm i think the Original should use direct Usb support as in Usb.
And the unbranded ones user Virtual Serial port and herein is the problem.
Either you get it working or just get frustrated..
But its only my thought..i may be wrong but read it somewhere.
freshseasons is offline
Old 25-07-2007, 06:08 PM   #12 (permalink)
dhan_shh's Avatar
Recently,I got a DKU-2 cable from eBay for just Rs.135(inclusive of delivery charges)!!!
h**p://cgi.ebay.in:80/ws/eBayISAPI.dll?ViewItem&item=190131573503&sspagenam e=ADME:L:AAQ::1
It's working very well!!
dhan_shh is offline
Old 26-07-2007, 12:21 AM   #13 (permalink)
Google Bot
Pathik's Avatar
Imo fake data cables and memory cards r very good vfm and perform well
Pathik is offline
Old 26-07-2007, 07:13 AM   #14 (permalink)
Mobile Freak
reddick's Avatar
No problem...go for unbranded...It will work also
reddick is offline
Old 27-07-2007, 07:09 AM   #15 (permalink)
Norms Buster
Finally got an unbranded USB Data cable for Rs.250
http://www.ca42.com/
VexByte is offline
Does Nokia 6030 suuport data cable transfer? esumitkumar Mobiles and Tablets 50 07-10-2008 12:18 PM
nokia 3220 data cable problem tintin Buying Advice 24 24-05-2006 07:56 PM
Nokia 6030 data cable problem lavan_joy Buying Advice 5 31-03-2006 09:57 AM
Wanted Data Cable for Nokia 1100 zeeshan_04 QnA (read only) 2 03-09-2004 05:46 PM
