19-07-2007, 09:42 PM
"The Gentleman"
N70 or N72 or N73 or W810i
guys which one should i buy N70 or N72 or N73 or W810i, i will be using by mobile to its optimum & will b installing many softwares, so i thought since symbian cells have many softwares designed for them, should i stick to some N series??... suggest me which one to buy ?? sometimes its hard to decide will one to buy even after knowin them well, gimmie proper suggestin plz. waiting for replies 2 pour in.
and yes i will be buying second hand mobile and can make up the budget to buy them so no need to bother about the budget.( but once if i buy d mobile i cannot change it, so i hav 2 decide it carefully & dont want to regret later).
music quality should be equal ==== to w810i (both in earphone and in inbuilt speakers)
Thanks in advance.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
19-07-2007, 09:45 PM
Host4Cheap.org
Re: N70 or N72 or N73 or W810i
5700 - It rocks
http://www.host4cheap.org/
19-07-2007, 09:46 PM
"The Gentleman"
Originally Posted by sukhdeepsinghkohli
5700 - It rocks
do u have one??? is it a symbian phone or java ??? does it have all features of N Series ?? i also want a phone with good music quality = w810i
- Dijkstra
19-07-2007, 09:53 PM
Wire muncher!
Originally Posted by vish786
guys which one should i buy N70 or N72 or N73 or W810i, i will be using by mobile to its optimum & will b installing many softwares, so i thought since symbian cells have many softwares designed for them, should i stick to some N series??... suggest me which one to buy ?? sometimes its hard to decide will one to buy even after knowin them well, gimmie proper suggestin plz. waiting for replies for pour in.
Thanks in advance.
n73, if u can spend that much or else 5700.
19-07-2007, 09:55 PM
I suggest N73ME.
Don't go for N70,a friend of mine has it & it is running even slower than my Nokia 3230  {It takes about 20-25 sec to open Gallery}
N72 is good if you want value for money.
SE W810i doesn't have symbian AFAIK.So you won't be able to install softwares.
19-07-2007, 09:59 PM
"The Gentleman"
thanks for replyin dude, was waitin for ur reply  honestly.
i'm worried about the music quality coz nokia sound quality is not that great except for its loudness while playing mp3s.
oh dude i want only bar phones, and 5700 is twist phones i dont like them.
what about n72 , is its sound quality equal to w810i ???
yes i know.... my friend has w810i i only told him as he only wanted music phon
- Dijkstra
Reason: Automerged Doublepost
19-07-2007, 10:28 PM
Host4Cheap.org
1. Yes...my cousin has it and i have to buy it within this week
2. Better than N series. I must say it only lacks Wi-FI for me
3. Screen has 16 million colors while N series have 262 144 colors.
4. Its Symbian and that too latest and bst one
5. 5700 is actually a music phone. Its called 5700 XpressMusic and has a Audio Chip unlike N series
19-07-2007, 10:45 PM
yeah n73me man.....since i see budget not a prob
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
19-07-2007, 11:04 PM
"The Gentleman"
whats the difference between n73(normal) and n73 music edition ???
- Dijkstra
19-07-2007, 11:29 PM
Google Bot
jus updated firmware and a better music player and themes.. Btw go 4 a n73me or 5700
19-07-2007, 11:44 PM
Noobie Pro
If you want to install softwares, then rule out w810i.
Amongst the cells you selected, go for N73.
And if you want something newer than that, go for 5700, only minuspoint will be a camera not as goos as N73.
www.twitter.com/alsiladka
19-07-2007, 11:56 PM
Wire muncher!
updated firmware which includes a better music player plus music adapter. i must say the default sound quality of n73me is quite comparable to w810i. thru better earbuds and optimal equiliser settings the sound quality is pretty much comparable to w810i. but then it adds to the cost. nevertheless n73me is a great package. a 3.2mp cam and symbian are its strongpoints when compared to w810i. since its a candy bar phone its quite sturdy.
but if u are specifically targetting a music phone out of the box wid pretty decent cam and bother about nothing else then w810i. u may also haf a look at w610i.
gud luck in choosing a cell of ur choice!
ps: btw, 5700 bundles a very good headset. its got a twisting mechanism btw, and even the cam's on the twister. i personally think its not a great idea!
19-07-2007, 11:59 PM
"The Gentleman"
ok guys my last question... is sound quality of n72 = n73??,
i'm thinking of settling down on n72. wat say??
Thanks guys for ur precious replies.
- Dijkstra
20-07-2007, 12:01 AM
Wire muncher!
NO
NO again.
n72 is good value for money phone. but its got an inferior cam, comes wid a lesser capacity mem card, no music adaptor, comes wid an older symbian os. if u are considering n72 and symbian os is not ur main concern then i'd suggest u to buy w810i/w610i. that is the only strongpoint of n72. everything else is against it when compared to those SE phones.
20-07-2007, 12:06 AM
"The Gentleman"
@infra_red... thanks a million times dude.
wats the price of n72 and n73, new and second hand ??
and second hand w810i ??
- Dijkstra
20-07-2007, 12:11 AM
Google Bot
n72-9k
n73me-16k
5700-11.6k
n70-10.4k
my vote 5700
20-07-2007, 12:13 AM
"The Gentleman"
@pathiks,,, thanks dude
wats the price for w810i and w610i ??
- Dijkstra
20-07-2007, 12:30 AM
gooby pls
W810i-11.9k
W610i-12.8k
20-07-2007, 12:31 AM
#19 (permalink)
Wire muncher!
~12k and ~13k respectively.
edit: whoa! techgenius beat me by few seconds!!!
20-07-2007, 12:37 AM
#20 (permalink)
* Teh Flirt King *
N72 : Value 4 money. (I have it and I am satisfied).
For music N73 is better but for reading (which I think you will not do on a phone) N72 is my choice.
And dunno why my N72's bettery last longer then my friend's N73's bettery...
20-07-2007, 12:38 AM
#21 (permalink)
CG Artist
Originally Posted by Tech Genius
W810i-11.9k
W610i-12.8k
Which is better out of these two?
20-07-2007, 12:39 AM
#22 (permalink)
* Teh Flirt King *
NO
NO again.
I got a music adapter with my Phone (N72), I can plug it into my 3500 Watt Speaker System.
20-07-2007, 12:42 AM
#23 (permalink)
"The Gentleman"
both r same dude except w610i has 2.4x zoom and w810i has 4x zoom
Originally Posted by Quiz_Master
N72 : Value 4 money. ( I have it and I am satisfied).
how is the music quality in n72??, since u own it, i'm asking.
- Dijkstra
20-07-2007, 12:45 AM
#24 (permalink)
gooby pls
W610i supports A2DP and walkman player 2 while everything same.go for w810i.
20-07-2007, 12:46 AM
#25 (permalink)
Wire muncher!
i don't think the music adaptor is a standard accessory. its a separate buy i believe. its a bundled accessory only wid the music edition phones afaik. correct me if i'm wrong.
Quote:Originally Posted by Tech Genius
W810i-11.9k
W610i-12.8k
look here: http://www.thinkdigit.com/forum/show...1&postcount=18
20-07-2007, 12:49 AM
#26 (permalink)
"The Gentleman"
@infra_red_dude....
dude can u post all ur threads (which u had started)which r related to w810i/w610i software and firmware installation. it might help for tweaking d cell.  sorry for the trouble.
- Dijkstra
20-07-2007, 12:52 AM
#27 (permalink)
CG Artist
Thanks guys.I am also going to buy a phone.This thread will help me.Because i am also considering the same phones which vish has considered.
20-07-2007, 12:55 AM
#29 (permalink)
CG Artist
@vish if you are going for N73 then you can also consider K810i.Both have similar price.
20-07-2007, 12:58 AM
#30 (permalink)
Wire muncher!
most of those points haf been discussed here. haf a look at this thread: ne suggestions ?? budget 16.5k ??
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
w810i HELP
HEMANTRATURI |
Mobiles and Tablets |
14 |
17-01-2007 05:51 PM |
On SE W810i
navneeth_snr |
1 |
13-09-2006 08:20 PM |
W810i
harmads |
4 |
26-08-2006 11:51 PM |
Re:W810i - Please help !!
harmads |
3 |
04-08-2006 01:05 PM |
