Old 17-07-2007, 11:57 PM   #1 (permalink)
foreign return(0)
comrade's Avatar
Default Nokia 5500
So how is nokia 5500...i have seen so many threads suggesting 5200/5700...but its no where mentioned about 5500..am stunned against its features..being a symbian v9 rel 3 fone its available for just 7.5k @ univercell.
Some reviews were against its keypad....anyone here had any such problems.
am planning to replace my 6260 with 5500..suggestions plz..
http://www.gsmarena.com/nokia_5500_sport-1557.php
comrade is offline
Old 18-07-2007, 12:01 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Nokia 5500
good sports fone.. Good for 7.5k
Pathik is offline
Old 18-07-2007, 12:50 AM   #3 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
Good choice. 5500 is good,
Except that key-pad, and my friend says Video Recording is crappy too.
Quiz_Master is offline
Old 18-07-2007, 08:15 AM   #4 (permalink)
Noobie Pro
alsiladka's Avatar
well i would not suggest 5500 to you. It was built keeping sportsperson in mind, so that they could track their fitness and helth. It has a pretty small screen as well as a formfactor.
It was not built as a daily multimedia phone, you would better go for a E50.
www.twitter.com/alsiladka
alsiladka is offline
Old 18-07-2007, 09:06 AM   #5 (permalink)
assasin's Avatar
i've used a 5500 for bout 6 months.overall its a gr8 fone,but for the crappy keypad.sound thru loudspkr is just gr8.only prob is the keypad which comes off after bout 2-3 months of usage,though u can easily replace it.
assasin is offline
Old 18-07-2007, 12:09 PM   #6 (permalink)
krazyfrog
Posts: n/a
The only problem i see with it is the small display. Too small for viewing videos or surfing the net. Otherwise its overall features are excellent and definitely recommended at 7.5k.
Old 18-07-2007, 02:08 PM   #7 (permalink)
foreign return(0)
comrade's Avatar
if the keypad issue is solvable then i think its gonna be a good deal..
my current 6260 has got 176X208 so comparing to that one 208X208 is ok i think...thank u all for sharing ur experience.
comrade is offline
Old 18-07-2007, 02:50 PM   #8 (permalink)
assasin's Avatar
the display area of 6260 is bigger than 5500.
assasin is offline
Old 18-07-2007, 04:00 PM   #9 (permalink)
foreign return(0)
comrade's Avatar
how can it be....what does the figures then indicate
176x208
208x208
comrade is offline
Old 18-07-2007, 05:16 PM   #10 (permalink)
assasin's Avatar
176x208
208x208
208x208 is the total no of pixels that make up the display area.
N76 has a 2.4in 240x320 display and 5700 has 2.2in 240x320 display.
u can decide the display size just based on the pixel count.
assasin is offline
Old 18-07-2007, 05:25 PM   #11 (permalink)
krazyfrog
Posts: n/a
More number of pixels in less area make for a really sharp and attractive picture but also puts strain on ones eyes as everything looks small. Same number of pixels on a larger area make for more relaxed viewing. E.g. W880i has 240x320 pixels in a display measuring 1.8" whereas N95 displays the same number of pixels in 2.6". W880i's display maybe sharp and exciting to look at but N95's larger real estate make for a better overall picture which is also easier on the eyes.
Old 18-07-2007, 05:43 PM   #12 (permalink)
Google Bot
Pathik's Avatar
the screen resolution from the screen size
Pathik is offline
Old 18-07-2007, 06:28 PM   #13 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
It's a good phone except the keypad.
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 19-07-2007, 10:20 AM   #14 (permalink)
Boom Boom Boom
cooldudie3's Avatar
my current 6260 has got 176X208 so comparing to that one 208X208 is ok .
dude it's a small monitor for a symbian phone and bad in videos and surfing the net(all symbian phones have huge monitors)
but i think 6260 has a smaller monitor
I'm back! Gimme a hugggggg... :D
cooldudie3 is offline
Old 19-07-2007, 11:52 PM   #15 (permalink)
Google Bot
Pathik's Avatar
^^ wat did u just say??
The 6260 has a lesser pixel density but a larger screen
Pathik is offline
Old 19-07-2007, 11:59 PM   #16 (permalink)
foreign return(0)
comrade's Avatar
ok then i guess i need to settle for e50 which is the next close competitor @ 1.5 K more..
e50 @ 9k & 5500 @ 7.5k
comrade is offline
Old 20-07-2007, 12:07 AM   #17 (permalink)
Google Bot
Pathik's Avatar
hmmm.. The e50 is a good fone.. I myself use it.. Tho dont expect much in the cam and music dept
Pathik is offline
Old 20-07-2007, 12:14 AM   #18 (permalink)
foreign return(0)
comrade's Avatar
cam is secondary for me..but sound should be loud enough when loud spkr turned on
but am concerned about video recording...can i improve the video quality by using any of the 3rd party softs available like eti camcorder,etc...
comrade is offline
Old 20-07-2007, 12:24 AM   #19 (permalink)
Google Bot
Pathik's Avatar
video rec. Isnt good in the e50 and the ldspkr sound is just average..
Pathik is offline
Old 24-07-2007, 11:08 AM   #20 (permalink)
Boom Boom Boom
cooldudie3's Avatar
if about videoing go for n93i but quite expensive
Nokia 5500 Sport Tech Geek Mobiles and Tablets 6 08-02-2007 06:29 AM
Calling Owners of SE K750i or Nokia 5500 for Help techtronic Mobiles and Tablets 31 16-01-2007 10:39 AM
Nokia 6233 or Nokia 5500 sports merawalaid Mobiles and Tablets 22 25-12-2006 12:03 PM
