Old 09-07-2007, 12:45 PM   #1 (permalink)
Back in Power
almighty's Avatar
Default 6020 connection prob
I am using nokia 6020 as modem with DKU-5 Data Cable, Airtel GPRS.
i am able to connect with pc after reinstalling my xp
what i ve done wrong during installation
i am using nokia pc suite 6.83.14.1
what is the problem
before reinstalling xp i used 6.6 nokia pc suite
and without any trouble am using it
plz guide me where and how to config my set up
as i searched on net i see lodz of prob like mine
but no exact solution..so i thot to ask u frnds coz this forum have realy genius members
help me plz
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
Old 09-07-2007, 03:52 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: 6020 connection prob
If 6.83 doesnt work for u then try using the version that u got along wit the fone in a cd...
Pathik is offline
Old 09-07-2007, 09:47 PM   #3 (permalink)
Back in Power
almighty's Avatar
i roll back to previous version but cant able to connect
wth is tat
is dere anyway by which i can connect to net using ma cell?
almighty is offline
Old 10-07-2007, 01:21 AM   #4 (permalink)
You'r Born Free
int86's Avatar
If you dont have the original nokia cable than you have to install cable driver prior to Pc Suite.
# Money, Beauty and Configration has no ends.
# Life is like game sometimes. Play it or loose it. But keep the spirit of game.
http://en.wikipedia.org/wiki/Right_to_Information_Act
int86 is offline
Old 10-07-2007, 01:33 AM   #5 (permalink)
Beneath The Eyelids
The Outsider's Avatar
Problems with DKU-5 cable for Nokia
first get the phone detected properly(check the 2nd and the 7th reply) , then uncheck the option in "pc suite>Manage Connections" then install the phone as a modem through "control panel>add hardware"
The Outsider is offline
Old 10-07-2007, 11:29 AM   #6 (permalink)
Back in Power
almighty's Avatar
phone is not detecting wat sud i do
i check on another pc dere with some effort cell connected :O
plz help me frnds
almighty is offline
Old 10-07-2007, 01:00 PM   #7 (permalink)
You'r Born Free
int86's Avatar
If ur cell got connected on other pc, then u will hv to reinstall xp. But at first install cable driver that came with cable.
int86 is offline
Nokia 6600 Connection via BT Prob. vivekrm007 Mobiles and Tablets 5 19-01-2007 02:33 PM
IM In Nokia 6020 kkg_mjh Mobiles and Tablets 13 14-08-2006 09:39 AM
Nokia 6020 Official Techie Mobiles and Tablets 1 20-02-2006 01:45 PM
nokia 6020 Official Techie Mobiles and Tablets 2 10-02-2006 03:46 AM
MySql Administrator , connection prob ! help Butterfly QnA (read only) 1 07-10-2004 08:30 PM
- by tv6952
- by soumya
