Re: Pop 3
can u plzz aks the question more clearly ???
some info
Yahoo.com does'nt allow u to acess email thru Outlook or cellphone for free...u need to pay
but yahoo.co.in does allow u access via pop3 clients like outlook and my cellphone
best is Gmail.....u even get notification to ur cellphone when u get mail and also u can easliy access it frm cellphone
and buddy my advice create a new account and tell ppl to send only txt msgs to that id !!
and how to set gmail for cellphone is exactly the same as how u set for outlook !!
find it out in the google website or gmail help...
Email Address: Enter your full Gmail email address (username@gmail.com)
Server Information
Incoming mail server (POP3): pop.gmail.com
Outgoing mail server (SMTP): smtp.gmail.com
Login Information
User Name: Enter your Gmail username (including @gmail.com)
Password: Enter your Gmail password
# Click More Settings... and then click the Outgoing Server tab.
# Check the box next to My outgoing server (SMTP) requires authentication and select Use same settings as my incoming mail server.
# Click the Advanced tab, and check the box next to This server requires an encrypted connection (SSL) under Incoming Server (POP3).
# Check the box next to This server requires an encrypted connection (SSL) under Outgoing Server (SMTP), and enter 465 in the Outgoing server (SMTP) box.
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
Reason: Automerged Doublepost
