Old 24-06-2007, 09:02 PM   #1 (permalink)
The Sexy Beast
Question How 2 charge your phone dialing a 3 digit no.??
my friend told me he had read in Bombay Times a month ago u could charge your phone by just dialing 3 digits
is it true and what no. I have a Airtel conn. and also a MTNL Trump conn.
ratedrsuperstar is offline
Old 24-06-2007, 09:07 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: How 2 charge your phone dialing a 3 digit no.??
Crap... u cant charge ur fone by dialling a no.. tho there were some codes to save battery but even they dont ork on new fones...
Pathik is offline
Old 24-06-2007, 09:14 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Yeah! There was a code to charge Samsung "CDMA" mobile phones but believe me it doesnt work.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 24-06-2007, 09:40 PM   #4 (permalink)
Stay Silent!
enticer86's Avatar
yaar c it logicallly
they mean u can use NETWORK to charge up ur BATTERY
how is that possible
infct i believ network [or lack thereof] is responsible fr battery usage
I saw me running,
'Twas a long, long run.
But the view was so stunning,
And that made it so much fun... ©
enticer86 is offline
Old 24-06-2007, 10:30 PM   #5 (permalink)
Stalker's Avatar
does he mean re-charge his account balance or something??
Stalker is offline
Old 24-06-2007, 10:40 PM   #6 (permalink)
Dreamweaver
Gigacore's Avatar
may be
Gigacore is offline
Old 24-06-2007, 10:44 PM   #7 (permalink)
a_k_s_h_a_y's Avatar
long time back i had got a message on orkut saying that if we type some code then the hidden battery power will get activated and we can use it.....
may be he is talking abt it.....
a_k_s_h_a_y is online now
Old 24-06-2007, 10:46 PM   #8 (permalink)
Stalker's Avatar
hidden battery power getting activated...lol .........orkut is full of crap!
Stalker is offline
Old 24-06-2007, 10:47 PM   #9 (permalink)
Wandering in time...
Ankur Gupta's Avatar
^^That code was *3370# which restarts your phone with 50% more battery but its crap and this code works only on older phones like Nokia 2100...
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 24-06-2007, 11:10 PM   #10 (permalink)
ok i digged out my orkut saved messages (abt 300)and here it is
Subject: Hidden Battery power
Imagine your cell battery is very low , you are expecting an important call
and you don't have a charger. Nokia instrument comes with a reserve
battery. To activate, press the keys *3370# Your cell will restart with
this reserve and the instrument will show a 50% increase in battery. This
reserve will get charged when you charge your cell next time.
hmm so even ankur says same...who knows....neva tried it...
Old 24-06-2007, 11:29 PM   #11 (permalink)
harryneopotter's Avatar
it really works ... for me ... and there is no hidden battery power ... it just increases battry power by 30 % ....by reducing voice quality ... as it uses a less complex(or simple) algo to decode voice .... and new generation phns have this feature by name like "change active speech codec" ... so its not crap ... it works on my 2100 ... and if u wish to change the algo again ... just press #3370# ..........
harryneopotter is offline
Old 25-06-2007, 12:30 AM   #12 (permalink)
The Sexy Beast
yeah that's somewhat what my frnd said 50% power-up when u dial that no. good for me i'm using a nokia phone
will see in a while coz my battery is already full
Old 25-06-2007, 09:52 AM   #13 (permalink)
Stay Silent!
enticer86's Avatar
hey guys tht code is all crap. As per Nokia HQ ppl, the codes such at *3370#, #3370# and *4720#, #4720# were incorporated in fones til the n7250 line of production. The purpose was to enable *CODEC FOR BTTER VOICE *smthing [i cudnt understand wht my uncle who works thre meant] but thats NOT activating hidden power. it was supposed to b used way bak whn the networks were not very strong and this code wud basically reboot the fone, putting more than/less thn normal pressure to try to boost signal strenght [dependin on * or # ]
Nowadays its redundant coz the netwrks r stronger
and sm old geeks feel tht putting half pressure wud put 50% more life in battery while using the logic tht reduced network boost reduces battry use... its not directly related u c
I saw me running,
Old 25-06-2007, 10:01 AM   #14 (permalink)
Commander in Chief
QwertyManiac's Avatar
Pressure? What do you mean by pressure in code? As in timeout seconds and retries?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 25-06-2007, 10:05 AM   #15 (permalink)
Stay Silent!
enticer86's Avatar
i cudnt understand
I saw me running,
Old 25-06-2007, 10:41 AM   #16 (permalink)
Originally Posted by enticer86
i cudnt understand
ts simple u see ....in older times ..whn netwrks were weaker ...the handsets used two type of algorithms to decode or decompress voice over network .... so after pressing *3370#, the phone would restart and started to use a less complex decoding algo which uses less battery power and hence increasing battery back up upto some extent ... but as now u knw that netwroks are far much stronger ...so no algo is needed to boost voice quality and hence the code is incorporated in new gen phones ....got it now ???????
Old 25-06-2007, 04:50 PM   #17 (permalink)
!FREEWARES!
Akshay's Avatar
Thr is no such method like dialing 3 digit no. to charge ur cell n evn if u enter d codes listed above, thr is no 50% increase in ur battry life. I hav tried it. It is only a few extra min. u get wit it...
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 25-06-2007, 06:20 PM   #18 (permalink)
Microsoft MVP
Actually cell phone doesnt utilize total amount of battery just like our laptops.
In laptop, it automatically shut downs/hibernates system based on pre-defined battery level. Like when the battery reaches 3% power, the laptop will automatically hibernate/shut down. But u can change this 3% level from Power Settings.
Same case applies in cell phones, it automatically switch off at a pre-defined battery level. And u can decrease this level and can allow cell phone to fully utilize the battery by using such codes.
But such codes don't give noticable amount of battery backup, just a few extra minutes, which are hardly to notice.
[Modem Problem] No dialing.. Please help.. //siddhartha// Networking 11 30-12-2006 02:23 PM
dialing through pc Terahertz Mobiles and Tablets 6 19-01-2006 11:19 AM
dialing using sify mohnishghodekar QnA (read only) 1 13-12-2005 05:56 AM
Dialing Problem uk_tyagi Software Q&A 3 08-12-2005 06:37 AM
Did Digit Phone U...... Aseem Nasnodkar Mobiles and Tablets 7 15-02-2005 03:10 PM
