Old 24-06-2007, 06:54 PM   #1 (permalink)
GONNA GET ALL OF YOU
JohnephSi's Avatar
Default Nokia 5200
will opera mini,a java application programme run on Nokia 5200
What is the processor 4 nokia 5200 ? Is it Java or Symbian. Iam asking it after thorougly surfing the mobile review of this fon
JohnephSi is offline
Old 25-06-2007, 11:13 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Nokia 5200
arey yaar how many topics ll u make..??
YEs opera mini ll work on it...
Btw it has a ARM processor but a s40v2 os so it ll run only java apps...
Pathik is offline
Old 25-06-2007, 11:15 AM   #3 (permalink)
Stay Silent!
enticer86's Avatar
i gues this dude isa AWARE CUSTOMER
tooo awke
I saw me running,
'Twas a long, long run.
But the view was so stunning,
And that made it so much fun... ©
enticer86 is offline
Old 25-06-2007, 03:25 PM   #4 (permalink)
Google Bot
Pathik's Avatar
arey itna AWARENESS is injurious to health....
not his... our health...
Pathik is offline
Old 25-06-2007, 04:16 PM   #5 (permalink)
Stay Silent!
enticer86's Avatar
^^ agree bro.. n i gues both of us r the only GUD SOULS helpin him
I saw me running,
Old 25-06-2007, 07:48 PM   #6 (permalink)
krazyfrog
Posts: n/a
^^ Keep helping and only your souls will be left of you.
Old 25-06-2007, 09:02 PM   #7 (permalink)
Stay Silent!
enticer86's Avatar
hope so
I saw me running,
Old 27-06-2007, 02:10 PM   #8 (permalink)
JohnephSi's Avatar
enticer can u browse internet using opera mini 3 in Nokia 5200 ? If so plz tell me the steps
Old 27-06-2007, 02:39 PM   #9 (permalink)
a_k_s_h_a_y's Avatar
first of all allow opera mini in ur cellphone to access web !!
there will be a option called permissions sum whr in ur cell
opera mini shld hv the permission to acess internet on ur cellphone!!
basically those java progs dont work like in ur case if they are denied access to user data and net...
then open opera mini goto menu and tools and settings in thr select option Network setup...it will automatically set it up
if this dont work then thr in network setup u change that protocol to SOCKET and try if this dont work then again change Protocol to HTTP and try
if none work...then i dont know find some one in ur city who can set it up for u in front of u
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is online now
Old 27-06-2007, 02:55 PM   #10 (permalink)
JohnephSi's Avatar
I cant even goto menu and tools and setttings since usually opera starts network setup sutomatically when we run it first. Bt 4 me it does not.Plz someone hel me. I found that in my configuration setting 4 my handset there is acess point bt i cannot add my mo setting there but there is a setting of Airtel live .How is it so. I really dont no so idelete the airtwl live aceess point .Plz help me in adding the acess poin ot MO
Old 27-06-2007, 03:17 PM   #11 (permalink)
krazyfrog
Posts: n/a
Go to settings>connections>gprs. There you'll find the answer to your problems. There you can create new access points and then select it as default for all apps. Hope you know the settings for MO. If you don't, DO NOT create a new thread. Ask here or search the forum.
Old 27-06-2007, 06:14 PM   #12 (permalink)
Stay Silent!
enticer86's Avatar
n pls dude mujhe maaf karo...
i dont hav anythin called nokia 5200.. i donno anythin abt gadgets..
main sanyasi hun, aajkal m in the Alps-----> modern sanyas u see
I saw me running,
Old 27-06-2007, 06:21 PM   #13 (permalink)
krazyfrog
Posts: n/a
Didn't knew they setup net connection in the Alps. Thanks for telling .
Old 27-06-2007, 09:17 PM   #14 (permalink)
Stay Silent!
enticer86's Avatar
Cool Re: Nokia 5200
arey i told na
modern sanyas
I saw me running,
Old 02-07-2007, 01:06 PM   #15 (permalink)
JohnephSi's Avatar
Plz tell me how 2 check battery status 4 Nokia 5200
Old 02-07-2007, 01:25 PM   #16 (permalink)
krazyfrog
Posts: n/a
you see the battery shaped bar at the top right corner of the screen. Thats what i do.
Old 02-07-2007, 02:19 PM   #17 (permalink)
JohnephSi's Avatar
Bt how can i check my pc. of the battery.Is there any programs 4 it.
Old 02-07-2007, 03:31 PM   #18 (permalink)
krazyfrog
Posts: n/a
No. Atleast i don't know any. Why do you need it any way? Isn't the battery indicator enough for you?
Old 02-07-2007, 05:20 PM   #19 (permalink)
Stay Silent!
enticer86's Avatar
he is very aware yaar
now the govt shud tk away jaago grahak jaago campaign
I saw me running,
Old 02-07-2007, 08:52 PM   #20 (permalink)
JohnephSi's Avatar
I need it because i oftenly surf 2 internet through my mobile through data cable .Also it does not charge the battery automatically like my past SE W 700i .How to do it in my 5200.
Old 02-07-2007, 09:00 PM   #21 (permalink)
Wire muncher!
infra_red_dude's Avatar
its not possible in nokia phones as the charger port is separate from the data port.
infra_red_dude is offline
Old 02-07-2007, 09:18 PM   #22 (permalink)
JohnephSi's Avatar
Which means i need to charge the phone quite oftenly.Will it not affect my battery
Old 02-07-2007, 09:24 PM   #23 (permalink)
krazyfrog
Posts: n/a
You can charge your battery as much as you want. Nothing will happen to it.
Old 02-07-2007, 09:28 PM   #24 (permalink)
JohnephSi's Avatar
My friend has 3110 Classic ? Bt i cannot see any difference with my 5200.Wht r the upgradations in 3110 C
Old 02-07-2007, 10:36 PM   #25 (permalink)
Wire muncher!
the biggest noticable difference is the camera. 3110 has a megapixel cam while urs is jus a vga cam (0.3 mega pixel).
Old 02-07-2007, 10:53 PM   #26 (permalink)
krazyfrog
Posts: n/a
3110c also has a 262k TFT display compared to 65k STN in 5200.
Old 03-07-2007, 10:24 AM   #27 (permalink)
JohnephSi's Avatar
Wht ??? 5200 too has 262k
My battery drains away quickly when i surf internet through it.How can i solve it
Old 03-07-2007, 10:31 AM   #28 (permalink)
Wire muncher!
keep the charger plugged in. its a separate port anyway.....
Old 03-07-2007, 11:51 AM   #29 (permalink)
Google Bot
Pathik's Avatar
using gprs drains the battery faster.. U cant do anything about it anyway..
Pathik is offline
Old 03-07-2007, 12:03 PM   #30 (permalink)
Stay Silent!
enticer86's Avatar
^^ does MULTI CHANNEL GPRS also drain battery faster ???
I saw me running,
Nokia 5200 enticer86 Mobiles and Tablets 7 24-07-2007 10:12 AM
problem in nokia 5200 jatt Buying Advice 3 04-06-2007 11:23 PM
Wallys on Nokia 5200 ashu888ashu888 Mobiles and Tablets 7 15-03-2007 05:50 PM
Nokia 5200 - Suggestion Required utsavhanda Buying Advice 16 04-03-2007 09:53 PM
