Old 24-06-2007, 06:18 AM   #1 (permalink)
Default serious matter
Hi Friends….
This is Qadir………. Looking for a serious help from u ppls hope u ppls will solve my problem
Here I go…….
Im using nokia 7610…. From past few months I have a problem with it,
One day suddenly the whole display was gone white…. I switched off for a while and restart it again and it was became normal… after few week I face that problem again so I did a soft format…… It was well for few months…..
But now a days im facing the same problem again…. So I did a hard format…. And this time no format is solving my problem…… after the hard and soft format’s its be well for few hours and again goes to full white……. I don’t know what to do
One of the professionalist has said it was due to virus… I said but I formatted many times for this he said no virus deleted completely from the mobile its just compressed some where in ur hand set after a certain time it may start it work again
Now tell me guys what can I do…..? Im not using mmc, updating the firmware may solve my problem…..? how can I update my firmware by my own……? There is no option in nokia site…… can I update by any other site……?
Please guys…… do help, it urgent…….
I will be very thankful to u ppls……
qadirahmed is offline
Old 24-06-2007, 10:19 AM   #2 (permalink)
krazyfrog
Posts: n/a
Default Re: serious matter
Update it by taking it to nokia service centre. If you're phone is out of warranty they'll charge around 200 rupees for the update.
Old 24-06-2007, 04:28 PM   #3 (permalink)
any other suggestion.........?
Old 24-06-2007, 06:48 PM   #4 (permalink)
Asterisk enthusiast
abhasbajpai's Avatar
when the display becomes white, dose removing the battery and then again putting it back, and starting the phone solves the problem for time being ???
i had this too in my old 3650 and culprit was the battery as it was 2 years old (like my phone) replacing the battery solved my problem.
abhasbajpai is offline
Old 24-06-2007, 10:16 PM   #5 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
please put appropriate thread titles in future.
n00b forever...
~Phenom~ is offline
Old 25-06-2007, 11:14 AM   #6 (permalink)
Google Bot
Pathik's Avatar
^^ wat is it wit ur rank dude???
btw yea get it flashed at a nokia care center
Pathik is offline
Old 25-06-2007, 04:45 PM   #7 (permalink)
!FREEWARES!
Akshay's Avatar
It is definitely not a virus. May b loose conn. or something but firmware seems to b an obvious reason. For manually updating ur firmware, chk nokia site. Dey hav given step by step procedure. But it may b risky to do so on ur own.
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 25-06-2007, 07:38 PM   #8 (permalink)
krazyfrog
Posts: n/a
^^ 7610 cannot be updated by ourselves since Nokia does not provide its update online. AFAIK only phones after 6630 can be self updated.
Old 25-06-2007, 09:30 PM   #9 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
Smile Re: serious matter
Nothing, just trying to be funny.
n00b forever...
~Phenom~ is offline
Old 26-06-2007, 12:31 AM   #10 (permalink)
ok.... thanks to all of the members...... i have submitted fone to a professionalist........ let's see what he gonna say.......
Ill inform u all.........
Thanks again...........
Old 28-06-2007, 06:49 AM   #11 (permalink)
Cool Re: serious matter
Assalaam Aleikum bhai, i also have the same problem, i think u have to flash it, though i did not flash mine. Get ur firmware upgraded. No battery probs or loose connection of that sort. This is the prob with 7610 i think. Did u use it extensively for net using PC, i think its a big stress on the phone. Get it flashed Inshallah it will be solved. Though i am usin a N 73M for 5 months.
rajarshi7 is offline
A Matter of Speed emailaatif786 QnA (read only) 22 09-03-2007 12:35 PM
Does Megapixels matter???? maharajadhiraj Mobiles and Tablets 8 13-06-2006 12:57 AM
certifications matter?? logicbomber QnA (read only) 2 01-07-2005 08:04 PM
Plz plz plz help on DVDRip matter Manoj QnA (read only) 2 03-05-2005 09:39 AM
Matter or Not ????? FasTrack QnA (read only) 10 30-09-2004 09:22 AM
