Old 13-06-2007, 09:21 PM   #1 (permalink)
sujeet2555's Avatar
Red face nokia 6600
i have nokia 6600 with 256mb mmc card.when i installed a program,it says to rplace the version.i insllaed the software.but after that all the phone icons was gone and it give me system error when openinig any programs.i know it the card that is the culprit. but is there any way that i can repair my card without formatting it.i don't have a card reader yet.please answer!
s.k.
sujeet2555 is offline
Old 13-06-2007, 09:23 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: nokia 6600
scan it with any antivirus like netquin or symantec..
Pathik is offline
Old 14-06-2007, 07:38 PM   #3 (permalink)
sujeet2555's Avatar
there is no virus,i have scaned it.it is some setting problems,i think.
s.k.
Old 14-06-2007, 07:45 PM   #4 (permalink)
krazyfrog
Posts: n/a
Does the phone work properly without the memory card inserted? If yes then the problem is in the phone and not memory card. Unfortunately formatting seems like the only option. Since you don't have a card reader and the 6600 doesn't support data cable, you won't be able to backup anything.
Old 15-06-2007, 12:38 AM   #5 (permalink)
you can backup using pc suite....
Simbly speaking...............Get a good mobile!!!!!!!!!!!!!!!!!
oval_man is offline
how i can use Nokia 6600 cam as web( help!!!) pawan Mobiles and Tablets 1 14-05-2006 09:02 AM
how i can use Nokia 6600 cam as web( help!!!) pawan Mobiles and Tablets 3 12-05-2006 05:59 PM
nokia 6630 or nokia 6600 maharajadhiraj Mobiles and Tablets 8 25-02-2006 01:22 AM
N-gage QD or Nokia 6600 or Nokia 3230 anks84in Mobiles and Tablets 3 20-12-2005 01:59 PM
Can we use Nokia 6600 as USB key? jerry146 Peripherals 2 22-01-2005 12:38 PM
