Old 09-06-2007, 06:22 PM   #1 (permalink)
Om Ma Ni Pä Me Hum
phuchungbhutia's Avatar
Exclamation sony w700i sound prob
i bought my se w700i mob in march there is a prob with its speaker ... it is not loud enough compared to other mob even if i listen to its full it still does not plus it gives out disturbing off bad sounds at
high vol .. i dont have any ear piece prob though .. its only with the speaker .. do i need to update or do some tweakin .. any help
Om Ma Ni Pä Me Hum: (perfection of-)
Om: generosity,- Ma: pure ethics,-Ni: tolerance n patience.- Pä: perseverance,- Me: concentration,-Hum: wisdom... Using Opera Mini Airtel NOP
phuchungbhutia is offline
Old 09-06-2007, 07:43 PM   #2 (permalink)
krazyfrog
Posts: n/a
Default Re: sony w700i sound prob
When you say compared to other phone, do you mean other W700i or some other model?
Old 10-06-2007, 02:30 PM   #3 (permalink)
Om Ma Ni Pä Me Hum
other mob like nokia 6600 se w800 are louder .
Old 10-06-2007, 03:39 PM   #4 (permalink)
krazyfrog
Posts: n/a
Don't compare it with other models. That way the volume level will always differ. Compare it with other W700i. If the sound is still low there is a problem with the speaker and you'll need to get it repaired. If its the same as other W700i, then thats the way it is and you can't do anything about it.
How to turn off camera sound in W700i ? esumitkumar Mobiles and Tablets 8 26-03-2007 11:31 AM
Battery prob in W700i esumitkumar Mobiles and Tablets 8 12-01-2007 10:34 PM
Sony Ericsson W700i anandf12000 Mobiles and Tablets 3 26-12-2006 09:21 AM
IM in sony ericcson w700i jamyang312 Mobiles and Tablets 2 24-09-2006 10:47 AM
