| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#1 (permalink) |
Dont die of ignorance . |
#3 (permalink) |
Still Shining!
This problem happens when the player's file system gets corrupted.
The files will be present but it will show no files and while copying a file windows will take around half an hour. What you have to do is, first switch on the player. Then with a sharp pointed object like the tip of a ball-pen press and hold the RESET button for five seconds. The player will get switched off. Now, hold on the play button and connect it the computer. Generally this problem happens in one particular folder. So, you can leave that one and copy the rest to your hard disk. Your MP3 files are in it. Now again remove it and reconnect it. Start the Transcend Firmwire update program. If it says "cannot lock device", then goto Task Manager and shutdown explorer.exe and try again. Better restart windows. Then start the Update software and then connect the player. It will be ok.
Simplicity is the ultimate Sophistication HP dv6 6121tx: Core i7 2630 QM | 4GB | AMD 6770M 2GB GDDR5 | 640 GB Nokia N86 8MP |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Tsonic 610 does not showup in My Computer | Nariman | Hardware Q&A | 4 | 11-05-2007 09:22 AM |
| Transcend Tsonic 610 or 630 | Praneet | Mobiles and Tablets | 5 | 04-02-2007 06:46 PM |
