LinkBack (2) Thread Tools Display Modes
Old 14-10-2008, 01:11 PM   #61 (permalink)
Here Since 2003
Indyan's Avatar
Default Re: Patch ur SE phone to improve on the features!
shadyator_root : Dont post in upper case. It's considered rude.
And you need to reflash your phone. Make sure you install the proper custpack along with the main and fs.
My Blog :: http://www.pallab.net
Twitter :: http://www.twitter.com/indyan
Indyan is offline
Old 01-10-2009, 01:09 AM   #62 (permalink)
Thanx infra_red_dude alot, your posts really help me much.
But I've got trouble with my memory card. I had a 4Gb MS Pro Duo, it still works using card reader but not work when inserted in my W700, can you help me fix this?
Nevermore is offline
Old 01-10-2009, 01:39 AM   #63 (permalink)
Wire muncher!
infra_red_dude's Avatar
^^^ Maybe format it with the correct filesystem? Does your phone at least recognize the card? If so then you can try formatting the card from within your phone.
infra_red_dude is offline
Old 01-10-2009, 05:44 AM   #64 (permalink)
AJJU
azzu's Avatar
w700 supports 4gb so thats not the Problem
as Infra said format it with correct filesystem or try it in other mobile and Format it .
OFFTOPIC : anIRUDH dude ur back after lotta dayz ?
I love and Live to Design
azzu is offline
Old 01-10-2009, 06:24 AM   #65 (permalink)
Wire muncher!
@azzu: Yeah dude, been busy with projects and exams
Old 01-10-2009, 11:29 AM   #66 (permalink)
Thanx you guys.
My phone does not recognize it, I've not tried it with another card yet. At the moment I don't have other W here. So can you tell me more about "format it with correct filesystem", can i format it with my PC using some particular software?
My card onced formatted by PC. I think that's why i have this problem.
Old 01-10-2009, 12:53 PM   #67 (permalink)
AJJU
azzu's Avatar
may be thats the issue i once formatted my MStick on comp but my k790i detected it and said MS corrupted formate it i did format on mobile and it solved the issue
so i suggest u to format ur memory card on other mobiles which detect it (any se mobile that ur card fits)
it will work
azzu is offline
Old 02-10-2009, 07:41 AM   #68 (permalink)
Thank u azzu.
Ok I'll try it though it might not be done soon cos SE is alittle not popular in my country (Nokia rules). But I really like SE-W series and W700 is the best imo.
Old 02-10-2009, 08:32 AM   #69 (permalink)
AJJU
azzu's Avatar
Wink Re: Patch ur SE phone to improve on the features!
Wat In our Country ? arent u from India ,, okay waz jokin
yea SE is not as popular as NOKIA but in my city even pan dabbavala knows the music difference between SE-W580 and nok N-70
azzu is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/59663-patch-ur-se-phone-improve-features.html
Forum Planete-SE > SonyEricsson W810i This thread Refback 25-02-2012 11:38 AM
Hvordan blokke nummere? - Norsk Freakforum This thread Refback 09-11-2011 11:08 PM
Cell phone features Edburg Mobiles and Tablets 15 24-04-2007 06:12 PM
Application Compatibility patch & Animated cursor vulnerability patch for VISTA kirangp Technology News 3 04-04-2007 08:57 AM
improve appearance of xp varunprabhakar Software Q&A 15 03-01-2007 04:53 PM
Does Win 2K SP4 improve sys performance slugger Software Q&A 1 15-07-2005 05:25 PM
