Originally Posted by aks_win
good music and good fm and also cam with auto focus and flash (absent in 6300)
get a k550i wid hpm-70 headset + at least a 512mb card. this may not be under 12k. if u are hell bent on getting it under 12k then i'd suggest u buy k750i + hpm70 headset + 1gb card. the only thing u'll miss is edge.
u can also buy w610i but it'll cost abt 13.5+tax. the hardware is same as k550i. so ppl haf succeeded in flashing k550i to w610i. but if u dun wanna take this risk then i'd suggest a w610i u get everything out of the box u've mentioned! but before buying anything do check out the keypad in a dummy.
