Imagine ur cell battery is very low, u r expecting an
important call and u don't have a charger.
Nokia instrument comes with a reserve battery. To
activate,
key is "*3370#"
Ur cell will restart with this reserve and ur instrument
will show a 50% incerase in battery.
This reserve will get charged when u charge ur cell
next
time.
*3370# Activate Enhanced Full Rate Codec (EFR)-Your phone
uses the best sound quality but talk time is reduced by approx.
5%
#3370# Deactivate Enhanced Full Rate Codec( EFR)
*#4720# Activate Half Rate Codec - Your phone uses a
lower
quality sound
but you should gain approx 30% more Talk Time
*#4720# Deactivate Half Rate Codec
2 *#0000# Displays your phones software version,
1st Line : Software Version,
2nd Line : Software Release Date,
3rd Line : Compression Type
3 *#9999# Phones software v ersion if *#0000# does not work
4 *#06# For checking the International Mobile Equipment
Identity
(IMEI Number)
5 #pw+1234567890+1# Provider Lock Status. (use the "*"
button
to obtain the "p,w" and "+" symbols)
6 #pw+1234567890+2# Network Lock Status. (use the "*" button
to
7 #pw+1234567890+3# Country Lock Status. (use the "*" button
to
8 #pw+1234567890+4# SIM Card Lock Status.(use the "*" button
to
9 *#147# (vodafone) this lets you know who called you last
*#1471# Last call (Only vodofone)
10 *#21# Allows you to check the number that "All Calls" are
diverted To
11 *#2640# Displays security code in use
12 *#30# Lets you see the private number
13 *#43# Allows you to check the "Call Waiting" status of your
phone.
14 *#61# Allows you to check the number that "On No Reply"
calls
are diverted to
15 *#62# Allows you to check the number that "Divert If Unrea
chable(no service)" calls are diverted to
16 *#67# Allows you to check the number that "On Busy Calls"
are
diverted to
17 *#67705646#R emoves operator logo on 3310 & 3330
18 *#73# Reset phone timers and game scores
19 *#746025625# Displays the SIM Clock status, if your phone
supports this power saving feature "SIM Clock Stop Allowed", it
means you will get the best standby
time
possible
20 *#7760# Manufactures code
21 *#7780# Restorefa ctory settings
22 *#8110# Software version for the nokia 8110
23 *#92702689# (to rember *#WAR0ANTY#)
Displays -
1.Serial Number,
2.Date Made
3.Purchase Date,
4.Date of last repair (0000 for no
repairs),
5.Transfer User Data.
To exit this mode -you need to
switch
your phone off then on again
24 *#94870345123456789# Deactivate the PWM-Mem
25 **21*number# Turn on "All Calls" diverting to the phone
number
entered
26 **61*number# Turn on "No Reply" diverting to the phone
number
entered
27 **67*number# Turn on "On Busy" diverting to the phone number
entered
28 12345 This is the default security code press and hold #
Tips / undocumented functions:
- At the top of the main-menu and every folder, the keys 1 to 9 are shortcuts to the icons 1-9
- A shortcut on the left menukey in standby-mode will take more time to open than a shortcut on the right menukey. Reason: The left key is also used for the keylock so it shortly waits for pressing the * button.
- While writing text press and hold "#" to switch between Alpha mode and Number mode. You can also press a key long to insert its number.
- In standby-mode, press and hold 0 to launch your wap home page.
- If you have your keylock activated just press the on/off button to turn on your backlight to look at the time when it's dark without having to unlock the keypad.
- To keep the backlight on, run Torch (freeware), press and hold the Menu button and go somewhere else on the phone.
- To check your current firmware version simply type *#0000# in standby screen.
- To check your IMEI (International Mobile Equipment Identity) type *#06# in standby screen.
- To check your Bluetooth device address type *#2820# in standby screen.
- Start up in Safe Mode (no 'auto start' apps will be running): Hold down the pencil key when you turn on the phone and hold it on until you have to enter your PIN code.
- Format the phone memory by typing *#7370# in standby screen.
- In standby mode,
45# + <talk> dials the number on your sim in memory slot 45.
50# + <talk> dials slot 50 and so on.
*# 06 # Seriennummer/IMEI indicates (actually also a GSM is code - see further below)
*# 0000 # SW version announcements (e.g. V3.42.1, 16-10-03, Nhl-10)
*# 2820 # Bluetooth (BT) device address indicate
xx # Directory quick access (xx = storage location and afterwards lozenge e.g. 24 #)
A/from key Short pressing for menu for switching between profiles
Menu key Long pressing for "task manager" - switching between active programs (with "C" key programs can be terminated.)
Menu quick access Over in the menu e.g. to point 3.1 arrive simply 31 enter (if the third symbol a file is opened is for these and then in it started the first Programm/Icon).
Autostart go around When switching on of the Handys on to the pin inquiry the key "ABC" (pin) comes the whole time keeps pressed - this is to ignore (allegedly) the autoinitialization programs.
# Do not switch between different lines (AS)... goes e.g. with Austrian ONE Handys (see nose cunning). I could not try out however also, since I did not have 2 lines on the SIM map.
12345 ... is according to standard set the Nokia nokia-Sicherheitscode.
0000 ... is according to standard those (with Vodafone windshield frame section) set 2te pin and that standard net code/password
With D1 the standard net code is the last 4 numbers of the card number without HLR e.g. 99999234-5/55 - > 2345
0 - for a long time press If one the "0" in the main menue for a long time presses those homepage of the standard WAP connection is called.
MMC Card --------------------------------------------------------------------------------
Your files in MMC are stored in multiple (disk) blocks.
So if you format using 16K block, the space used will be 16K eventhough your file is just 1K.
If you buy MMC, it is usually preformatted with 16K block. Therefore alot of space is wasted as most installed program files are usually less than 2K.
You will need a card reader to do this:-
1. Connect card reader and copy all your files in the MMC to computer disk.
(Make sure you set the show all/hidden/os files to "on")
2. Do a format of the MMC using command line "format" and use the /A=size option.
Alternative, you can use the Disk Management in Adminstrative Tools to format.
Make sure you select FAT. For 256MB MMC, smallest block you can use is 4K, 128MB is 2K, 64Mb is 1K and 32MB is 512B.
(Note: You cannot use the phone "format MMC" to do this as the format just clear the allocation table and does not change the block size)
3. Copy back all files to MMC.
Now you will find that you will have more space.
256mb MMC got back 30+ mbs
Caution - starting from here the codes are "dangerous"
*#7370925538#
* # of res wallet # ... is to be deleted the code around the "wallet"! Input like normal telephone number (not in wallet code inquiry windows).
NOTE! Afterwards the "wallet" is empty, can again be put on however with new code.
*# 7780 # The "original attitudes" and telephone re-establishes is again started (an appropriate inquiry and it follow before must the sicherheitscode be entered).
NOTE! Afterwards various "attitudes" are away - among other things these:
·1 Points of entrance (Provider dependent points of entrance and attitudes)
·2 Bluetooth attitudes
·3 Favorite
·4 Allocation of the two keys (beside Navi keys) in the main menue
·5 Profiles are "neglected" (as with distribution) - still there however new bell tones, etc. are...
·6 SMS/MMS/E Mail attitudes
·7 Logos and spielstaende (allegedly) also deleted...
Programs, calendars and contacts, etc. not changed...
Also the sicherheitscode remains.
This putting back goes also via menu under "attitudes - general - original telephone once.".
*# 7370 # Soft format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a software RESET. (however still another inquiry comes before.)
NOTE! If the Akku to 75% are loaded at least, Akku do not only accomplish during the procedure under any circumstances remove! The procedure takes some minutes (approx. 3-4), is absolutely waiting!
This is "only" a soft format... Hard format with "green, 3, *"... see below.
Green, * 3 Hard format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a RESET.
Proceeding: Equipment switch off, which keep "green key" (take off) at the same time pressed, "*" and to "3" key and switch the equipment on (the keys thereby keep further pressed)... to "Formatting" on the display appears...
If that does not function, then equipment for 1 hour switch off, Akku so for a long time rausnehmen and again try.
"only" virtual the memory is generally cleared - genuine formatting can take place only in a Nokia service center, if the Fash is deleted there and/or new L.G. is installed.
Mixed * # 92702689 #, then switch - system menu off (goes with me not)
The following code do not fold (with me also):
* EFR0 # (* 3370 #) EFR activate (EFR = Enhanced Full rate Coding - language optimization)
# EFR0 # (# 3370 #) EFR switch off
* HRC # (* 4720 #) HRC switch on (HRC = helped rate Coding - language compression)
# HRC0 # (# 4720 #) HRC switch off
SIM LOCK Simlock status query: (use "*" the key over "p,w" and "+" indications to enter)
# pw+ 1234567890 +1 # Provider LOCK status
# pw+ 1234567890 +2 # network LOCK status
# pw+ 1234567890 +3 # Country LOCK status
# pw+ 1234567890 +4 # Sim Card LOCK status
The code 1234567890 must be computed with a program e.g. SmartDCT4Calc and/or DCT 4 code Calculator from IMEI, etc....
Info. to Simlock: SIM LOCK makes it for the offerer/network carriers possible, subsidized (verguenstigte) Handys to offer. Thus one makes oneself if necessary punishable if one SIM LOCK deactivated - in addition the warranty can purged. I take over for it no adhesion or responsibility!
GSM code ... should function at each Handy - however Netz(betreiber)abhaengig are... and "harmless"...
Generally applies: First enter code, "send" afterwards (< send green key > press) and one moment wait...
SMS Tipps To Tipps & cheat about SMS (with appropriate codes) are immediately in the FAQ list .
For example for the topic: SMS "retard" and/or deferred send, acknowledgment of receipt, reports...
Mark more simply To Tipps & cheat to the topic "mark" e.g. with SMS entrance.
Over simply to mark simply the "pin" (ABC key) hold some e.g. SMS and move then Jostick downward.
Call number transmission * 31 # - { CLIR - Calling LINE identification Restriction switches on for the general call number transmission **
# 31 # - switch off the general call number transmission
# 31 # [ telephone number ] - with the next call suppress the own call number (thus temporary)
* 31 # [ telephone number ] - with the next call transfer own call number (thus temporary)
* # 31 # - status query (of call number transmission)
# 31 * [ telephone number ] - own call number show, although receiving station switched call number suppression on. (is not usually de-energised of the Netz(betreiber).)
* 30 # - switch { TIE-clip - Calling LINE identification presentation for the announcement on of the call number of the caller **
# 30 # - switch off
* # 30 # - status query
This also partly goes with 6600 via Men: Attitudes - calls - own No. send...
The following codes are not supported by most Netz(betreibern):
* # 76 # - announcement of the call number, under which one reached the calling (not its call number during rufumleitung!) { COLP - COonnected LINE identification presentation **
* 76 # - switch on
# 76 # - switch off
* # 77 # - announcement of the call number, under which the caller reached me (not my call number during rufumleitung meinerseits!) { COLR - COnnected LINE identification Restriction **
* 77 # - switch on
# 76 # - switch off
Call bypasses (call Forwarding) Bypass code (U):
U=21 always
U=61 retards
U=62 not attainable
U=67 occupies
U=61, 62, 67 can be parallel active
U=21 - > and then no more call signaling overwrites U=61,62 and 67!
Service code (D):
Not all nets support all services
D=10 language and fax (all calls)
D=11 only language
D=12 all data (speed/minutes)
D=13 only fax
D=14 DATEX j (active?)
D=15 teletex (active?)
D=16 only SMS
D=18 all data except SMS
D=19 all services except SMS
D=20 all services
D=21 all asynchronous services
D=22 all synchronous services
D=23 3.1 kHz GSM of language services
D=24 all synchronous POINT ton of POINT DATA inclusive. PADs
D=25 only data (all asynchronous POINT ton of POINT DATA inclusive. PADs)
D=26 DATA pack exchange on the left of inclusive. PADs
D=27 services thru PADs
D=29 12 Kbps digitally left
** U * [ goal call number ] * D # - bypass switch on
Input without * D means bypass of all services
01.01.04 Bypass code (U):
U=21 always
U=61 retards
U=62 not attainable
U=67 occupies
## U ** D # - switch bypass off (individual bypasses and service code)
Without ** D all services are switched off to bypasses
## 002 # (all bypasses for all service codes switch off)
## 004 # (switch off only U=61, 62, 67 and for all service codes - thus ", not attainable, nonacceptance "occupies)
* # U ** D # - status of the bypasses query:
Input without ** D queries all services and bypasses
Bypass in the speaking and/or fax box: Number in bypass procedure with D=11 and/or 13 enter
Goal call number (e.g. D2-Netz: +49,172 xxx) and Handynummer without preselection (if necessary 172 replaces) enter.
Tap: During switched on rufumleitung "with occupied" being able "to reject" calls by one the red key during "to ring" presses. The caller is then passed on to the goal call number of the occupying bypass (e.g. mailbox).
Type for waiting period during rufumleitung 61: ** 61 * [ goal call number ] * 11 * [ time in sec. (5 to 30) ] #
This also partly goes with 6600 via menu: Attitudes - rufumleitungen -...
Knock/stops/parks/faults Knocks is signaling a secondary call during a current discussion
* 43 # - switch on
# 43 # - switch off
* # 43 # - status query
This also partly goes with 6600 via menu: Attitudes - calls - knocking...
0 < sends > - reject while the discussion a knocking
1 < send > - discussion terminate, knocking discussion accept
certain discussion (y) terminate 1 (y) < send >
2 < sends > - discussion park, knocking discussion accept
certain discussion and new discussion leads 2 parks (y) < sends >
0 < sends > - caller the busy condition signal
This also partly goes with 6600 via menus existing during the discussion.
Call barrier Possible only if bypass of the service code is switched off.
Check code (S):
S=33 all outgoing transmissions
S=331 outgoing abroad
S=332 outgoing abroad except home
S=35 all arriving transmissions
S=351 all arriving abroad
Special check codes (s) delete:
Switch off only in connection with the procedure
S=330 check code status outgoing & arriving transmissions switch off
S=333 check code status outgoing transmissions switch off
S=353 check code status arriving transmissions switch off
Service code (D):
D=11 only language
D=13 only fax
D=16 only SMS
D=20 all services
D=26 data packet exchange links incl. PADs
D=29 12 Kbps digital liNK
CHECK SIM-LOCK
Note - If you bought your Nokia on UK Vodafone or UK Cellnet you do not need to check this because they both transmit on GSM900, and they don't lock the phones. However if you bought your phone on UK Orange or UK One2one your phone may be blocked. The reason is that they both transmitt on GSM1800. To make a call on GSM1800 you need what is known as a "Dual band" phone. A dual band phone is able to transmit on both GSM900 and GSM1800, so they lock the phones so you can't use it with any other network simcard. If you find that your phone is locked you can try different software to unlock it. (we havn't found one that works yet), or you can ask your service provider who will gladly exchange the 10 digit code for about £35.
This is how to check the status of the 4 different locks. Aslo don't try entering the wrong number, because after 3 times it will block the phone for good.
There are 4 different locks on your Nokia phone.
COUNTRY-LOCK
NETWORK-LOCK
PROVIDER-LOCK
SIMCARD-LOCK
The code to read out the sim-lock status of your phone is
#PW+(MASTERCODE)+(Y)#
# = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO
Re: Nokia Secret Codes!!!!!!!!!!!!!!!!!!!!!!!!!
« Reply #1 on Today at 2:40am » [Quote]
THE JAMES BOND TRICK
If you short-circuit theleft middle and right pins on the bottom of the phone with all connections touching each other, the Nokia software hangs! The profile "Headset" will be activated. Before you do this just activate the "Automatic Answer" in the headset profile and set the ringing volume to "Mute". Now you can use your phone for checking out what people are talking about in a room. Just place it under a table in a room and call it. The phone receives the call without ringing and you can listen to what people are saying.
Clock Stopping
To check weather your SIM Card supports clock stopping type-
*#746025625# (*#SIM0CLOCK#)
To enter the service menu type-
*#92702689# (*#WAR0ANTY#)
Serial number (IMEI)
Production date (MM/YY)
Purchase date (MM/YY) You can only enter the date once.
Date of last repair (0000=No repair)
Transfer user data to another Nokia phone via Infra-Red
Code's for some older nokia phones
Nokia code
These Nokia codes will work on most Nokia mobile phones, however we accept no responsibility of any kind for damage done to your phone whilst trying these Nokia secret codes.
Nokia code Code function
*3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
*#4720# With this Nokia code you can deactivate the Half Rate Codec
*#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
*#9999# Phones software version if *#0000# does not work
*#06# For checking the International Mobile Equipment Identity (IMEI Number)
#pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
*#147# This lets you know who called you last (Only vodofone)
*#21# This phone code allows you to check the number that "All Calls" are diverted to
*#2640# Displays phone security code in use
*#43# Allows you to check the "Call Waiting" status of your cell phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
*#67# Allows you to check the number that "On Busy Calls" are diverted to
*#67705646# Phone code that removes operator logo on 3310 & 3330
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible
*#7780# Restore factory settings
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
**21*number# Turn on "All Calls" diverting to the phone number entered
**61*number# Turn on "No Reply" diverting to the phone number entered
**67*number# Turn on "On Busy" diverting to the phone number entered
press and hold # Lets you switch between lines
Nokia 1610 / 1611
*#06# for checking the IMEI (International Mobile Equipment Identity)
*#170602112302# shows the SW version.
Nokia 2010
To view IMEI number *#06#
To view Software Version enter *#9999#
*3001#12345 for field test mode and nam selection and some other stuff...
Nokia 3310
*#06# To find IMEI (International Mobile Equipment Identity)
*#7780# restores Factory Settings..(Memory, language, counters not included)
*#3110# for checking the phone's software (SW) - called firmware revision information.
*#746025625# [*#sim0clock#] to check if the Sim-Clock can be Stopped
(Sim-clock-stop is a kind of standby mode which will save battery time)
*#92702689# [*#war0anty#] Phone asks 'warranty code:'
Press the following warranty code:
6232 (OK) : Displays the Month and Year of Manufacture
9268 (OK) : Displays Serial Number
7332 (OK) : Displays the date of the last repairment - if found
7832 (OK) : Displays (if found) the date where the phone was purchased
37832 (OK) : Set the Purchasing Date MMYY (This date can be set only once!)
87267 (OK) : Transfers ALL phone numbers, Logo's, and ringtones from other gsm phones
Nokia 3810
To view Software Version enter *#3810#
Nokia 5110
*#06# To look for the IMEI of the phone
*#0000# shows the software version.
*#746025625# - [*#sim0clock#]
Looks if the sim clock can be stopped. Sim clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*3370# activates the Enchanced Full Rate, after the phone has been turned off. EFR produces better voice quality but also consumes more power.
#3370# deactivates the EFR, after the phone has been turned off.
*4720# Activates the Half Rate Codec, after the phone has been turned off. HRC produces poorer voice quality but gives your battery better stand-by times.
#4720# Deactivates the Half Rate Codec, after the phone has been turned off.
Enhanced Full Rate will give you much better sound quality when you enable it. The new EFR codec uses the ACELP compression technology. This technology allows for much great voice quality in the same number of bits as the older Full Rate codec. The older technology was called LPC-RPE. Both operate at 13 kilobits, but you take up more space on the network, so they can charge you more. Talk-time is reduced with about 5%
Half Rate will give you poorer voice quality, which gives the service provider the opportunity to have more calls on the network, and you might get a lower charge from them. Will give you 30% longer talk-time.
Nokia 5120
*3001#12345# gives access to NAM1 and 2, sw version, security, alpha tags and heaps of other stuff.
Nokia 5190
*#5190# shows the SW version.
*#92772689# (after removing the analog module) shows service menu.
*3001#12345[OK] to enter test mode.
*#639# to change NAM.
Nokia 6080 / 6081
*#0000# shows the SW version.
Nokia 6190
*#6190# shows the SW version.
Nokia 6150
*#92702689# to enter service menu.
You don't need the warranty-codes any more - you can just scroll through the information like in any other menu. It has the the same data as 81xx and 31xx phones (with "Edit" button for purchase date, and "User data transfer").
Menu:
1: Displays Serial Number.
2: Displays the Month and Year of Manufacture (0997)
3: Displays (if there) the date where the phone was purchased (MMYY) you can here set the Purchasing Date (Warning: You can only do this once - so be careful what you write...)
4: Displays the date of the last repairment - if found (0000)
6: The option is for transferring ALL the telephone data (from the memory) to a "box" so that the technician can fiddle with the phone without worrying about the data stored on it. Stuff stored on the SIM is not transferred, but who delivers their phone with the SIM?
Nokia 6120 / 6160 / 6162 (TDMA phones)
*#92772689# for checking ISDN number.
*3001#12345# for field test mode and nam selection and some other stuff...
*#9999# shows the SW version.
Nokia 6190
Nokia 7110
*#0000# To view Software Version.
*#3370# - Enhanced Full Rate Codec (EFR) activation. It will automatically restart.
*#3370* - Enhanced Full Rate Codec (EFR) deactivation. It will automatically restart.
*#4720# - Half Rate Codec activation. It will automatically restart
*#4720* - Half Rate Codec deactivation. It will automatically restart
*#746025625# - Sim clock allowed status.
*#92702689# [*#war0anty#] - takes you to a secret menu with 6 choices:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture (0997)
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repairment - if found (0000)
5. makes you capebel of transferring user data if you have the gear for it
6. shows how many hours the phone has been on
Nokia 8820 / 8860
Nokia 8260
Change Alpha Tag
The alpha tag is the message that is displayed on your phone when in digital coverage. This is normally transmitted by the network, but can be overidden to display a different tag. This is done by creating a tag for a personal/residential zone in the phone, and setting this zone to have the same settings as your normal carrier. So when the phone identifies the network system it believes it is in the personal/residential zone and displays the tag you have programmed.
1) Enter programming mode of the phone by keying *3001#12345#
2) Find out the ID of your operator by entering the NAM1 menu. Note the Home System ID setting. (16387 on Rogers AT&T in Calgary)
3) Scroll to and enter PSID/RSID lists (menu 7)
4) Select P/RSID 1
5) Scroll to PSID/RSID and change the setting to 1
6) Scroll to Connected system ID and change the setting to the ID of your system (eg 16387)
7) Scroll to Alpha Tag and enter the message you would like displayed.
8) Scroll to Operator code (SOC) and enter coed for your provider such as 2050 for Rogers or 2049 for AT&T
9) Scroll to Country code and enter 302 for Rogers or 310 for AT&T
10) Power cycle your phone and hopefully your message will be displayed
Note: This has only been tested in Calgary on the Rogers AT&T network so may not work on other networks.
*3001#12345# Programming Menu: NAMs, Fieldtest, Serial Number, P/RSIDs
*#639# Program Phone Number
*#92772689# Warranty Information, Serial Number, Life Timer, Build Date, Programmed Date (editable once only)
*#9999# Display Software Version
*#06# IMEI
*#0000# view Software Version
*#92702689# [*#war0anty#] secret menu:
4. Displays the date of last repairment - if found (0000)
5. Makes you capebel of transferring user data
6. Shows how many hours the phone has been on
*3370# Enhanced Full Rate Codec (EFR) activation
#3370# Enhanced Full Rate Codec (EFR) deactivation
*4370# Half Rate Codec activation
#4370# Half Rate Codec deactivation
xx# - xx position in Phone Book
NOKIA 9000
*#06# IMEI
*#682371158412125# soft version
*#3283# prod. date
NOKIA 7650
*#7979# phone reset
*#7470# hard reset
*#7370# master reset (like new phone)__________________
Link to Post - Back to Top IP: Logged
« Reply #3 on Today at 2:42am » [Quote]
Forgot your Lock Code? Try this NEW DCT3/DCT4 Master Code Calculator App. for S60!
MasterCode Calculator application for S60 (sis) By Dejan
All the users who have forgotten their Security/Lock Codes need not to worry. You just need to know your IMEI (International Mobile Equipment Identity) number.
To check your IMEI number, type *#06# on the main screen. This number can also be found on the backside of the handset. Just remove the battery.
You can have an application which will calculate the Master Code of your phone. This code can be used to change your present Lock/Security code.
DISTRIBUTION
You can freely make copies of the archive and distribute them as
long as no alterations are made to the contents.
DISCLAIMER
THIS SOFTWARE AND ALL THE ACCOMPANYING FILES ARE PROVIDED "AS IS" AND
WITHOUT ANY WARRANTIES EXPRESSED OR IMPLIED INCLUDING BUT NOT LIMITED TO
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE.
ANY MY LIABILITY WILL BE LIMITED EXCLUSIVELY TO PRODUCT REPLACEMENT.
IN NO EVENT SHALL I BE LIABLE FOR ANY DAMAGES WHATSOEVER (INCLUDING WITHOUT
LIMITATION, DAMAGES FOR LOSS OF BUSINESS PROFITS, BUSINESS INTERRUPTION,
LOSS OF BUSINESS INFORMATION, OR ANY OTHER PECUNIARY LOSS) ARISING OUT OF
THE USE OR INABILITY TO USE THIS PRODUCT.
All other trademarks mentioned herein are property of their respective
companies.
DESCRIPTION
MCode is software that runs on Symbian platform (S60) and allows you to calculate
Master Code for Nokia DCT3 (6110,8210,etc..) and DCT4 (8310,etc...)phones.
Once calculated Master Code is valid until IMEI is changed on phone.
It can be usefull if you forget 5-digit user code, you can always
use 10 digit Master Code!
Master Code unlock ONLY user lock code (default"12345") NOT SP lock code!!!
YOU CAN USE THIS SOFTWARE ONLY TO UNLOCK YOUR PHONE!, DO NOT USE ON OTHER PHONES!
***Program is tested on 6630(S60) and codes are tested on 6110,8210,8310!
If you have any problem with this program then just DO NOT USE IT!!!
If you are wondering what phone models are these.. here you go --
DCT-3 Phones :
3610, 2100, 3410, 6250, 3310, 3330, 3350, 3390, 6210, 5510, 5190, 6190, 8890, 8290, 5110, 5110i, 6110, 7110, 8810, 3210, 5130, 6130, 6150, 8850, 8210, 8250, 8855, 5210, 9110, 6090, CardPhone, CardPhone 2, Nokia 22
DCT-4 Phones :
D211, 3300, 3300e, 7210, 7250, 7250i, 6610, 6800, 6820a, 6650, 8910, 8910i, 8310, 3510, 6385, 6370, 1220, 1260, 1261, 7600, 3320, 3585, 3585i, 3570i, 6310, 6310i, 6100, 6200, 5140, 5100, 5100a, 3590, 6510, 3595, 3360, 6360, 8390, 6800a, 8270, 6590, 2285, 2275, 2270, 6108, 3108, 3510i, 8280, 6230, 6340i, 3560, 2280, 1100, 3100, 3120, 6220, 3520, 7200, 6560, 6225, 6230b, 3200, 3200b, 6585, 100b, 3220, 1100a, 2260, 2261, 2220, 2221, 3586i, 3105, 3220b, 3100b, 2650, 2651, 6015, 6016, 6019, 2112, 6011i, 2600, 2600cn, 3125, 6810, 2300, 2300a, 7270, 3205, 7280, 7260, 6255, 6256, 6012, 6020, 6020b, 6610i, 6170, 6170b, 6822a, 6230i, 6620, 9500, 9300, 7710, n-gage, 3600, 3620, 3650, 3660, 7650, 6600, N-Gage Qd, N-Gage QDa, 7610, 7610b, 6670, 6670b, 6260, 3230
So if your phone model is one of these and you've forgotten the lock code etc... you know whom to ask now
Note:
1> Download
2> Rename "McodeCalc.rar.txt" to "McodeCalc.rar" (remove .txt extention)
3> Unrar (Extract)
4> Send to phone
5> Install
Sorry if its a repost
