Old 01-05-2007, 11:19 PM   #1 (permalink)
The Techno Perv
Lightbulb Flash Menus in walkman series install guide
ok.. this is a guide to installing flash themes on ur se w810i,w300i, z550 etc phones.. i dunno if it works with k series..but am trying to find out.. for those of u who dont know wat i m talkin bout, chk out this video
Firstly, check ur firmware version.. do this by pressing >*<<*<* on ur joystick.. then go to service info
Secondly, Install USB flash drivers.. download them from here
then connect ur phone via the dcu-60 cable while keeping the "c" key pressed.. this brings up "found a new hardware wizard".. simply browse to the location of the above file to install the usb drivers.THIS STEP IS NECESSARY.. DO NOT SKIP THIS!!
download ur firmware file ( from topsony.com .mbn file).. if u own an 810i, this is the link to the firmware file
w810i firmware
i have a few firmwares on my comp. .. do let me kno if u need any.. if i have them, i'll upload
WARNING: Flashing ur phone can damage ur cell permanently IF NOT DONE CORRECTLY, i DO NOT take responsibility for the damage caused. so proceed at ur own risk.
MAKE SURE U HAVE FULLY CHARGED CELL BATTERY BEFORE PROGRESSING.
1. BACKUP ALL CONTENTS OF UR FONE.. SHUTDOWN UR CELL AND REMOVE SIM CARD
1. Download far manager and xs++
2. Download the SEFP plugins from here
SEFP010044
sefp010051
3. Extract FIRST SEFP010044.zip THEN sefp010051.rar to C:\Program Files\Far\Plugins
4. Download http://rapidshare.com/files/28928436...a.rar.zip.html and again extract it to C:\Program Files\Far\Plugins
5.Open xs++ and flash ur main with w810_p3k_dcu.49R.ssw (inside the above mentioned file). DO NOT CHECK ‘CUSTOMIZE UR FILE SYSTEM’
DO NOT FLASH UR FILE SYSTEM WITH THIS FILE!!!
It’s a break loader. After flashing with this loader, u cant start ur fone. It's only 5 flash blocks, should not take more than 30secs. Just choose STOP if it hangs on 100%.
6. Remove ur battery for 2-3 secs n put it back again.
7. Open Far manager and press F11
8. Here select SEFP 0.10.0.51 and hit enter.
• If you get the error: "Unknown exception", Exception address: 0x7C812A5B...... The plugin will be Unloaded!
This is a bug. It's because you don't have any COM-ports, so create a fake COM-port connection. I did it with my BT Dongle.
• if you get the error: "<BIldr> can be used with Service Cable ONLY".... browse to the SEFP folder and patch sefp.dll with sefp0.10.0.51patch.exe.
9. Next screen, select device as dcu-60, speed as 921600 and bootscript as w300_w810_z550_cid49 (for w810 i used this, for other models select the appropriate bootscript)
10. Hit Enter the matrix.
11. Now follow the instructions onscreen and u shd get a screen which says FS and Flash. Select FS press enter.
Here I shd tell u that the far manager screen consists of 2 window panes, the left pane shows ur phone contents like FS etc. and the right pane shows ur computer contents.
12. For flash menus, simply drag these files from the right pane in far manager and drop them on top of FS/tpa in left pane:
http://rapidshare.com/files/28933067/preset.rar.html
Make sure u drop the entire directory “preset” on top of fs/tpa.
13. After u r done with this, close far manager, Remove battery n put it back after 3 secs, n open up xs++ again.
14. Flash ur main with ur firmware with (.mbn) file. DO NOT CHECK ‘CUSTOMIZE UR FILE SYSTEM’
Once this is done, remove ur battery, put it back after 3 secs n start ur phone!! That’s it!
15. Download the Themes and put the .thm files in ur phone using sony ericsson suite or whichever software u prefer.
If u did everything exactly as I said, u shd get the flash themes.
U can also put in customised acoustic drivers, camera drivers,patches,media player skins etc. using this method!
In case u damage ur phone doing this, simply run SEUS n everything will be back to normal!
I would Like to thank infra_red_dude for the full support he provided me wen i flashed my fone for the first time
dtox is offline
Old 02-05-2007, 01:21 AM   #2 (permalink)
Gracias Senor
dreams's Avatar
Unhappy Re: Flash Menus in walkman series install guide
Hi..
Thnx for the info..
I am findin a site to d/l the new firmware for my w300i "R4EA031"..
But in topsony.com site it displays only the old version of firmware..
if sum1 has the firmware culd u pls upload it..i searched a lot..
TIA
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 02-05-2007, 01:53 AM   #3 (permalink)
The Techno Perv
Default Re: Flash Menus in walkman series install guide
dude i got this firmware for w300i.. http://rapidshare.com/files/17763944...C_JE_RED49.rar
its r9a036 generic je version.. and in my 9th point, put speed as 115200 if 921600 dosent work..
dtox is offline
Old 03-05-2007, 12:31 PM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
glad i cud be of help.....
nice job dtox.. a lot of people haf now bougt w810i. wud be a very useful guide for them
infra_red_dude is offline
Old 04-05-2007, 10:03 PM   #5 (permalink)
Wise Old Crow
blueshift's Avatar
Great article.
That >*<<*<* trick is really nice. There are so many customizations available there..but i didn't tried it. Will my warranty void if i change these??
btw how can i make my own menu thing?
blueshift is offline
Old 04-05-2007, 10:37 PM   #6 (permalink)
Wire muncher!
yes it'll be void. but u can get back to the original setup whenever u wanna claim warranty....
Old 05-05-2007, 06:21 PM   #7 (permalink)
The Techno Perv
yeah.. if u wanna change the menu icons, all u have to do is go to FS/TPA/PRESET/SYSTEM/MENU. There u will find a file called menu.ml.
MAKE SURE U BACK A BACKUP OF menu.ml IN CASE U SCREW ANYTHING UP!!!
Open it in wordpad or notepad n go to this line:
<element id="InternetServices">
<label type="name" textid="OLP_TITLE_TXT"/>
<icon pos="unselected" source="internal">DESKTOP_WAP_ICN</icon>
<icon pos="selected" source="internal">DESKTOP_WAP_SELECTED_ICN</icon>
<link type="internal"/>
</element>
once u find this, edit it to this:
<icon pos="unselected" source="file">xyz.png</icon>
<icon pos="selected" source="file">abc.png</icon>
</element>
this is to change "internet services" icon for example.. to change other icons, simply browse to the desired element id in menu.ml n make the same changes as above. Once u have made the changes, Save the new edited menu.ml in FS/TPA/PRESET/SYSTEM/MENU by overwriting the existing file and also put in the images u wish to make the icons.. in the above case, abc.png and xyz.png shd be put in FS/TPA/PRESET/SYSTEM/MENU along with menu.ml
btw.. this method works in w810,800,k750 etc fones..
dtox is offline
Old 05-05-2007, 09:48 PM   #8 (permalink)
Gaurav's Avatar
my personal advice, DON'T TRY IT., you will be void of your warranty.., if you are planning to purchase a new phone then go for it....
I tried it and my phone could'nt turn on, had to replace it from the service center..... (Scared of installing anything on my new phone)
The process is just too complicated...
Gaurav is offline
Old 05-05-2007, 10:57 PM   #9 (permalink)
shashank_re's Avatar
Will it work on w700i?(flash themes)
shashank_re is offline
Old 05-05-2007, 11:11 PM   #10 (permalink)
Wire muncher!
^^^ nope....... no flashlite support in w700i!!!
Old 05-05-2007, 11:17 PM   #11 (permalink)
The Techno Perv
hey buddy! I agree it is risky but i started fidling around with it since the day i got my fone.. if u have the corect guide n knowledge, there is NO WAY u can screw this up!! plus there is SEUS to help u out if u screw nething up.. its not as risky as u make it sound!!! i have flashed n reflashed my fone like 50 times now using the above method.. still runnin fine!
Oh, n b4 sending ur fone to the service center, u could have posted ur problem here , in this forum.. v might have helped u out with it.. as i see it.. ur fone couldnt turn on, yeah?? well..i had the same problem the first time i flashed n i just had to reflash my main firmware..!!
dtox is offline
Old 05-05-2007, 11:20 PM   #12 (permalink)
Wire muncher!
you needn't goto the service center. jus download the default flash files and flash it. this works in the worst case scenario too!
Old 06-05-2007, 05:23 PM   #13 (permalink)
Loading . . . please d'nt
CINTEL ENTRINO's Avatar
hey... dtox... i reacently bought the w810i....
but i dont know how to use the IR port.... how do i use it as a remote.... ??
CINTEL ENTRINO is offline
Old 06-05-2007, 06:03 PM   #14 (permalink)
Wire muncher!
IR port cannot be used for remote control of any sort.
Old 06-05-2007, 07:04 PM   #15 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
gr8 piece of info @dtox, thnx. btw, can u post some screenshots too??
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 06-05-2007, 07:18 PM   #16 (permalink)
i saw this.... so i asked
http://www.thinkdigit.com/forum/show...52&postcount=3
Old 06-05-2007, 07:47 PM   #17 (permalink)
The Techno Perv
check this video out:
http://www.youtube.com/watch?v=qRtzrVT5Xbo
see my attachments for screenshots
dtox is offline
Old 06-05-2007, 09:07 PM   #18 (permalink)
Back to l33ching :)
^^thank a lot dude. but isnt this in english???
Old 06-05-2007, 11:09 PM   #19 (permalink)
The Techno Perv
^^its in english.. the screenshot i got from a different site..
dtox is offline
Old 06-05-2007, 11:34 PM   #20 (permalink)
Tech.Masti's Avatar
looks good........
Tech.Masti is offline
Old 06-05-2007, 11:45 PM   #21 (permalink)
Back to l33ching :)
ok, thnx
Old 21-09-2007, 11:29 AM   #22 (permalink)
Salieri Family
hard_rock's Avatar
Location: Somewhere in Internet.......Have dynamic IP address
Thank you very much dtox and infra_red_dude!!
How do I backup my existing firmware and other stuff..So that if anything goes wrong I should be able to get my original 810i back..
The themes file link isnt working now. i downloaded files from here:
http://www.merlinstoll.nl/filedump/Themes/
Is it OK. They also have .swf flash files. Where to copy that.
A person who wants everything in his life... May end up with nothing at all
-Tommy[Mafia]
hard_rock is offline
Old 21-09-2007, 11:52 AM   #23 (permalink)
Wire muncher!
you can find the original firmware on SE-NSE. if you want you may backup the whole FS folder from far manager to save any customisations to the menus, drivers etc.
i guess the .swf files hafta be copied to the desktop folder inside TPA.
Old 21-09-2007, 03:36 PM   #24 (permalink)
all this is great . i have a s500i is it possible for me to install just the walkman player from walkman series mobiles without changing the whole firmware .
Dont die of ignorance .
digitizen is offline
Old 21-09-2007, 04:49 PM   #25 (permalink)
Salieri Family
hard_rock's Avatar
Can you give me the link to download the themes... The above link has only swf files in some themes. Actual theme will be in .thm format na..??
-Tommy[Mafia]
Old 21-09-2007, 05:02 PM   #26 (permalink)
a_k_s_h_a_y's Avatar
i think u can flash that phone to w580i !!!
u would love an w580i !!!!!!!
the looks of s500i and walkman of w580i is really a cool phone..
in this tut i hv given hunderds of flash menu !
Tutorial: Flashing k550i to w610i !!
i this tut i have also given how to convert non flash themes to flash themes
so u just need the .swf files
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is offline
Old 21-09-2007, 05:19 PM   #27 (permalink)
will flashing to w580i mess my phone ? . if something goes wrong will i be able to go back to the original s500i ?
Old 21-09-2007, 05:29 PM   #28 (permalink)
no u wont mess with it
back up GDFS and flash on !
also make sure u hv the an FS and MAIN of s500i
coz this can help u flash back
Old 21-09-2007, 05:33 PM   #29 (permalink)
well all this gdfs , fs and main sound greek to me . can u please point me to a proper tutorial ... please .
Old 21-09-2007, 05:37 PM   #30 (permalink)
u do this
just connect your phone to XS++
in my tut to flash k550i to w610i i hv put download link to XS++ !
and it will give details of your phone as soon as u connect to its left !
then just disconnect your phone and see the log file in XS++ folder and post that details here
i can see what are the details of the phone and tell u what next
Ubuntu 7.04 (Feisty Fawn) Install Guide! montylee Open Source 7 28-04-2007 09:29 PM
Install Flash on Ubuntu, Linux int86 Open Source 4 12-03-2007 05:25 PM
SE Walkman series or K750i??? cooldip10 Mobiles and Tablets 23 19-12-2006 12:49 PM
Is it possible to install win xp from a 1 GB usb flash drive rajiv.b Software Q&A 13 11-04-2006 01:20 AM
how to install application on series 60 phone bendre123 Mobiles and Tablets 2 07-11-2005 10:29 AM
