Old 30-04-2007, 07:15 PM   #1 (permalink)
Default N72 no call log
I have a Nokia N72 Recently it stopped showing Call Logs (Received/Missed/Dialled).
I checked with the Log Settings . The call Log Durarion is set for 30 Days and the "Show call duration is set to Yes".
Best Regards
Experience Is not Counted in Years.. But in the Countless Effort
www.kolasib.com www.zoram.org
valtea is offline
Old 30-04-2007, 09:39 PM   #2 (permalink)
sam_1710's Avatar
Default Re: N72 no call log
it happens at times... wid my N70!!
jus switch off ur mob and then restart it without the memory card.. after sometime switch it off again and then power it on with the memory card!! viola.. ur problem's solved!!
sam_1710 is offline
Old 03-05-2007, 08:32 PM   #3 (permalink)
Hell Sucks!!!
Upgrade it to latest firmware, ever since i have upgraded it, it hasnt appeared again (since last 20 days or so)
ashu_dps is offline
Old 04-05-2007, 08:35 AM   #4 (permalink)
.........Access Denied!!!
salilrane's Avatar
use once soft format
fst back ur all needed thngs ...
u r prob solved once for all
salilrane is offline
Old 04-05-2007, 11:09 AM   #5 (permalink)
Hell Sucks!!!
No it doesnt gets solved by it. Its some kinda bug in firmware. Have formatted it many times bt the prblm didnt used to get solved until the recent F/W upgrd
ashu_dps is offline
Old 09-05-2007, 04:49 PM   #6 (permalink)
Troubleshooter
Are you sure this works?? That's great if it does.. My friend has been suffering with her N72 with this problem. I've just now suggested her to do this. Will post once solved.
deepakchan is offline
Old 09-05-2007, 04:52 PM   #7 (permalink)
!FREEWARES!
Akshay's Avatar
Ppl with Firmware upgrade also face the same prb at times So thr has to b a diff. solution to dis. Phone restart definitely helps - as a temporary solution
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Akshay is offline
Old 09-05-2007, 07:28 PM   #8 (permalink)
Hell Sucks!!!
The latest f/w whch is avlbl since a last couple of weeks seems to have fixed it for me now.
Havent faced it since about a month now, whch earlier used to be atleast once a week!
ashu_dps is offline
Old 11-05-2007, 05:28 PM   #9 (permalink)
Troubleshooter
Can you post the firmware version?
Old 11-05-2007, 07:03 PM   #10 (permalink)
Hell Sucks!!!
Ya sure
Its
V 5.0705.3.0.1
30-01-07
RM-84
But its for N 70 bt i believe N 72 too has a new update
ashu_dps is offline
Old 11-05-2007, 07:09 PM   #11 (permalink)
sam_1710's Avatar
@deepakchan: It had happened wid my N70 some 3 months bak and doin so it worked!!
so did my method work for ur fren?? ..
sam_1710 is offline
Old 11-05-2007, 10:45 PM   #12 (permalink)
Troubleshooter
Gonna try it tomorrow only. She's out of station and is lazy to do these stuff even if instructed.
Old 11-05-2007, 11:47 PM   #13 (permalink)
sam_1710's Avatar
huh ha!!
gals will be gals!!
sam_1710 is offline
Old 17-05-2007, 08:43 PM   #14 (permalink)
thanks alot, the restart without memcard and then putting it back worked. i dont understand why this problem comes up, maybe its because of file system (phone mem + mem card) handling by the phone. Still looking for a permanent solution
valtea is offline
Old 18-05-2007, 01:08 AM   #15 (permalink)
sam_1710's Avatar
yup its because of the filesystem ofcourse!!.. n.. there is a permanent solution!!
Jus update the fone to the latest firmware, if its already updated, jus apply it once more!!
C2D E8400, MSI P45 Neo-F, Sapphire HD4850, Dell 2409W, OCZ 2*1GB RAM + 1*2GB Transcend + 1*1GB Transcend , Seagate 1TB + 2*Seagate 80GB, 600W SMPS, APC 600VA, Creative EP630, Sennheiser HD202
sam_1710 is offline
Unknown Call????????????? jiteshbhimani QnA (read only) 2 28-02-2006 10:24 PM
call of duty vasanth_12345 Gamerz 3 02-05-2005 04:42 PM
call for third umpire!!! club_pranay QnA (read only) 6 20-01-2005 12:29 PM
