Old 26-04-2007, 02:28 PM   #1 (permalink)
gsmsikar's Avatar
Default Airtel LG KG110 & GPRS?
can anyone tell me if it is possible to set the GPRS setting in a LG KG 110 mobile given with airtel bundle offer ?
it is gprs capable handset but i am unable to set its gprs ...
http://www.gsmarena.com/lg_kg110-1746.php
please help ..
thanks
gsmsikar is offline
Old 26-04-2007, 04:22 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: Airtel LG KG110 & GPRS?
LG KG110 is GPRS enabled. Hence you should be able to connect to Airtel GPRS. Call customer care and tell them the model make. They will tell you the procedure.
Settings vary from set to set.
However some things remain the same:
APN Name: airtelgprs.com
User Name and Password: blank
Kiran Kumar R
Kiran.dks is offline
Old 20-12-2007, 11:40 AM   #3 (permalink)
Beware of the innocent
ilugd's Avatar
how much does it cost each month? I mean the cheapest offer. I just got a kg110.
Life is too short. Have fun.
ilugd is offline
Old 22-12-2007, 01:58 PM   #4 (permalink)
Toh Fir aao
Ya buddy go ahead n use it,,,, My mom have lgkg110 n
sometimes when i want to download movies from- airtel FREE GPRS then
i used to BRIDGE two connection to get 20kBps+ so that i can download
them in night while asleeping
LGkg110 has gprs10 class modem n it'll give u good speed as m getting i
6 to 11 kBps on it alone...
But its Softwares are hard to find.....!!!!!
http://gstek.info || http://xscams.com || http://thetelecomnews.com
Join us over Gstek to experience latest on technology, Telecom, downloads etc
hac_king is offline
Old 02-01-2008, 11:53 AM   #5 (permalink)
ilugd's Avatar
i tried with the drivers as said above, but on connecting the mobile, the system still says unrecognized device connected to usb port
ilugd is offline
Old 23-09-2008, 05:10 PM   #6 (permalink)
Thumbs up Re: Airtel LG KG110 & GPRS?
i am also using lgkg110 mobile and i have activzated my GPRS but when i am connecting to internet it is displaying Invalid Settings.
Can u pls help me out with the settings required for using Airtel GPRS on lgkg110.
I will be xtremely thankful to u if u fwd me the details of settings and the procedure for connecting it.
Expecting +ve response .
Regards,
Santosh
santosh.sandhu20 is offline
Old 29-09-2008, 02:25 AM   #7 (permalink)
Toh Fir aao
@Santosh i am sorry for late reply
Btw in lg dialing right profile is a sevear task so use Extra initalization command.
type telephon.cpl in run box >> enter >> NODEM tab >> goto properties of lag modem you created >> GOTO ADVANCE tab and enter this command
AT+CGDCONT=1,"IP","airtelgprs.com"
juzz change access point to airtelwap.com if you are using NOP ..
You will be up in first try..
hac_king is offline
Old 30-09-2008, 07:55 AM   #8 (permalink)
mannuforall
mannuforall's Avatar
If you have any problem with your gprs setting and your cc cant help you then visit: http://gprs-settings-to-mob.rdr.cc
This can send gprs settings on your phone for free. Support any operator and any mobile handset in the world.
Here request for gprs settings by sms on given no. or put comments, and you'll get gprs settings on your phone for free.
Manojr Tiwari
http://www.mannuforall.in
You can also contact me for any UC Browser related info.
mannuforall is offline
Airtel GPRS sai_cool Mobiles and Tablets 55 19-05-2007 11:53 PM
Airtel GPRS vinaypatel Broadband and DTH 7 17-03-2007 03:35 PM
Airtel GPRS internet... chillnow Mobiles and Tablets 24 19-09-2006 12:40 AM
Airtel Gprs saiaspire Mobiles and Tablets 4 04-05-2006 04:53 PM
Airtel GPRS freezer Broadband and DTH 12 05-03-2005 04:32 PM
