Old 24-04-2007, 10:53 AM   #1 (permalink)
shashank_re's Avatar
Default Digital Camera-B'lore
Hi all,iam planning to buy a Digital Camera.After a lot of observations i have finally decided on Canon A710 IS
As iam nooooooob in the camera stuff,iam still a bit confused on my decision.So is there any other better camera than this which i should look for?
My budget is around Rs.13000 MAX .
And please tell me where i can buy this stuff from.And is grey market stuff reliable?
Finally iam really sorry if it is posted in the wrong forum......
shashank_re is offline
Old 24-04-2007, 11:07 AM   #2 (permalink)
Sup' dude, Sup'
Default Re: Digital Camera-B'lore
Hi Shashank,
Go to the GK Vale Store in MG Road. YOu can find lot of options there.
Selection:
Check the models in your budget in Canon, Nikon, Sony. Check how the menu navigation is and check how well it fit's in your hand, which one is most stable in your hands while taking a picture.
I will not suggest light weight and slim series cams for Noobs as it's difficult to keep the camera stable due to it's light weight body.
Once you get the models, go to the nearby net cafe and find out the reviews for the cams that you selected and buy the best one.
FYI, don't just rely on reviews. Check how you can handle it.
My pick is Canon or nikon.
Do not buy product worth 13k in grey market.
GK Vale: http://www.gkvale.com/products.html
ambandla is offline
Old 25-04-2007, 10:10 AM   #3 (permalink)
Ok.But i found the prices in G.K vale damn higher.I think i will settle with the Canon A710 IS.
After enquiring,the price of it in ebay and sify is around 13,500 but when i called the canon cust care,they said it is Rs.21,000!!!!! And iam not will to buy anything online.
So where else can i get that cam around 13k leaving grey market?
Someone please suggest me a good place to buy the cam from...........................................
Digital Camera.... BBThumbHealer Mobiles and Tablets 22 07-04-2007 04:09 PM
Digital Camera in 6 k tanmoy_rajguru2005 Cameras and camcorders 14 20-02-2006 11:41 PM
Digital Camera indian Cameras and camcorders 1 14-02-2006 09:56 PM
Which digital camera to buy... jay4u Cameras and camcorders 8 10-01-2006 11:00 PM
help me to buy digital-camera cyrix Cameras and camcorders 3 05-01-2006 11:22 PM
