Old 23-04-2007, 05:42 PM   #1 (permalink)
Resident Fanatic
Manshahia's Avatar
Exclamation Changing the font of Series 60...
Guys, how can we change the font of nokia 6630??
I hav seen my frnds fone and he says that he dont knw how this works...
Can any one plz tell me in detail how it works..?
Manshahia is offline
Old 23-04-2007, 05:58 PM   #2 (permalink)
sam_1710's Avatar
Default Re: Changing the font of Series 60...
create a directory called "Fonts" in 'C:\system' of your fone ...
and paste the files in the link..
http://rapidshare.com/files/27479642...r_N70.rar.html
dats it .. now u can use standard .ttf fonts (ones we use in windows) in ur fone.. by simply pasting them in dis directory!!!
by default theres a a s60 font file ("Acidnbase.gdr" - ull probably luv it)
NOTE : Ull have to restart ur fone if u change da font!!
sam_1710 is offline
Old 23-04-2007, 06:04 PM   #3 (permalink)
Google Bot
Pathik's Avatar
well use the GDR creator to convert ttf to gdr...
copy the gdr files to c/system/fonts
restart the fone...
to delete the font just rename the dir c/system/fonts to something else... delete it..
restart..
Pathik is offline
Old 23-04-2007, 06:08 PM   #4 (permalink)
sam_1710's Avatar
u may also try da method 'Pathiks' has mentioned... but for that u have to create a GDR font file using 'GDR creator'.
But sometimes the punctuation marks are not properly generated!!
sam_1710 is offline
Old 23-04-2007, 06:11 PM   #5 (permalink)
Resident Fanatic
Manshahia's Avatar
thnx for the help...
but can anyone provide me link to more .gdr files...
i m unable to compile the ttf fonts..
Old 23-04-2007, 06:13 PM   #6 (permalink)
sam_1710's Avatar
^^^ try my method... u can directly use the .ttf font files.!!
sam_1710 is offline
Old 23-04-2007, 06:14 PM   #7 (permalink)
Resident Fanatic
Manshahia's Avatar
if i hav a font like microsoft sans...
will i hav to delete all other gdr and tff files from that directory??
Old 23-04-2007, 06:17 PM   #8 (permalink)
sam_1710's Avatar
it goes like this.. the os looks into the first file in that directory...
but its better to remove the other files u arent usin!!
sam_1710 is offline
==> Whats Series 60? How2replace FONT? Full screen wallpaper!! <<== kool Mobiles and Tablets 6 16-02-2007 11:38 AM
ati 9800 series vs ati x1600 series vish786 Hardware Q&A 5 18-12-2006 12:48 AM
changing font on 7610? REY619 Mobiles and Tablets 4 17-12-2006 05:57 PM
Which is this Font ??? thrash_metal QnA (read only) 1 11-11-2005 06:05 PM
