Old 23-04-2007, 01:45 PM   #1 (permalink)
Default PIN Code Blocked
Hi guys,
i am using nokia n73.
My device is blocked & want PUK code.
Massage is Shown
" PIN code blocked. Enter PUK code:"
Plz help me guys to unlock the phone.
Kindly tell me PUK code......
Thanks in Advance.
vivekr is offline
Old 23-04-2007, 02:39 PM   #2 (permalink)
Default Re: PIN Code Blocked
Call customer care of your service provider and ask for the pin unblocking key(PUK)
ThinkFree is offline
Old 23-04-2007, 07:52 PM   #3 (permalink)
Wandering in time...
Ankur Gupta's Avatar
You get the PUK code when you buy a new mobile connection...
Check if you have the papers you got when you bought the conn..
And yeah dont enter wrong PUK code 10 times otherwise your SIM will get blocked and you will have to buy a new one then..
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 23-04-2007, 09:02 PM   #4 (permalink)
prasad_den's Avatar
AFAIK, the PUK code is given by the CC of the telecom company.. Only the PIN code is the default one in mobiles.. 1234 or something similar..!! I'm not sure though..
prasad_den is offline
Old 23-04-2007, 09:19 PM   #5 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
^^PUK is given by the telecom company
@vivekr...call up customer care
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 23-04-2007, 10:11 PM   #6 (permalink)
Alive Again...
satyamy's Avatar
Smile Re: PIN Code Blocked
Originally Posted by vivekr
Hi guys,
Massage is Shown
Thanks in Advance.
ohh ya
I have also suffered from this one
It happens if you enter wrong pin no. thrice
Open you cell phone
remove you sim card
see the no on its back
now call you cell operator (i.e. airtel, hutch or whoever you use) not nokia
call you customer care
ask for PUK no
they will ask for Sim no give them & you will get your PUK no.
enter it your cell will start working
satyamy is offline
p2p blocked!!! phanibhushan Software Q&A 5 04-04-2007 01:55 AM
orkut blocked sesi5674u Internet & WWW 13 08-02-2007 03:11 PM
ISU Blocked URL?? HELP... Manshahia QnA (read only) 5 01-02-2007 12:23 PM
Blocked or not abdulraqeeb33 QnA (read only) 8 14-12-2004 02:39 PM
