Old 23-04-2007, 09:13 AM   #1 (permalink)
Edburg's Avatar
Default Cell phone features
I am not sure what these features mean actually.So kindly help me in this:
1.What is RDS support in Radio FM player
2.What is HSCSD support
3.A2DP is playing music through bluetooth right ?? Is it bidirectional like playing from cell to computer and computer to cell.
4.EDGE is for internet connectivity right ?? Means we can use net in both cell and computer connected to it ? Then what is GPRS meant to do ??
5.Bluetooth speed increases from versions 1,1.1,1.2,2 right ??
6.3G is for video calls right ?? But Nokia 6233 is 3G without secondary camera
7.Sound quality increases as the no. of channels increase right ??
These may seem childish but i am ignorant about these.So waiting for answers.
Edburg is offline
Old 23-04-2007, 10:55 AM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: Cell phone features
1) radio data system. radio stations can air data like the station info, the song info, lyrics etc. which can be decoded by the fm player and displayed on the screen.
2) hi speed circuit switched data. its a data communication standard for hi speed communication. it can offer sppeds upto 115kbps. its somthing like a gprs standard.
3) thoeratically yes, a2dp is audio streaming from one device to other via bluetooth. the source and destination aren't fixed. so it shud be possible.
4) yes, yes, edge can be thot of and upgraded version of gprs in simple terms for better speeds.
5) yes
6) yes, but 3g is not exclusively for that. wid 3g u haf a faster communication channel which can be utilised for video calling. even the ages 6630 is a 3g phone but doesn't haf a second cam.
7) not necessarily true, it may or may not. it all depends on the reproduction of instruments by the synthesizer chip. but more channels always allow u to play more instruments simultaneously which maybe one of the factors for better sound quality.
nothing is childish pal. learning is an ever on going process!
infra_red_dude is offline
Old 23-04-2007, 10:56 AM   #3 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
1.)EDGE is for high speed net connectivity....
just go to www.answers.com/EDGE
2.)3G is not just for video calls...it stands for 3rd generation..which increases the data transfer rate and other features...
www.answers.com/3g
3.)I think the sound channel needs a larger description to make u clear....
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 23-04-2007, 12:16 PM   #4 (permalink)
Edburg's Avatar
Thx guys for ur answers it was much useful for me .
So 3G,EDGE,GPRS and HSCSD are all for high speed data trabsfers and communications .Its wierd why so many standards are req for this.
Edburg is offline
Old 23-04-2007, 12:29 PM   #5 (permalink)
Wire muncher!
hmmm.. lets make it simpler. consider each step as one generation (meaning one level up in ascending order)
1) gprs, hscsd
2) edge
3) 3g
hope its clear now.
Old 23-04-2007, 01:53 PM   #6 (permalink)
Edburg's Avatar
Yeah i am somewhat clear now.
But since they are in ascending order as u told, is the 3G feature alone enough to provide hi speed comm without requiring others ?
And N70 lack hscsd and k790i lack 3g,so does lack of one or other feature affect entire speed of communication ???
Edburg is offline
Old 23-04-2007, 03:38 PM   #7 (permalink)
Wire muncher!
yes 3g is enough. but here in india we do not haf the infrastructure to support 3g. hscsd is a parallel technology of gprs. as of now in india we haf edge over gprs network. so any phone which has gprs is able to access the net. and any phone which supports edge on gprs network will give decent transfer speeds. of corz lack of 3g has effect on the speed. but only if 3g service is provided by the service provider.
Old 23-04-2007, 05:46 PM   #8 (permalink)
Edburg's Avatar
oh i see thx for ur wonderful response.
So in india at present just edge alone is enough.I dont need to buy cell with HSCSD or 3G at present.Thx.
Edburg is offline
Old 23-04-2007, 06:26 PM   #9 (permalink)
Google Bot
Pathik's Avatar
if it has EDGE it ll have HSCSD... so tell us ur budget and we ll suggest u a good fone..
Pathik is offline
Old 24-04-2007, 08:18 AM   #10 (permalink)
Edburg's Avatar
I dont think that any phone with Egde will have HSCSD - have seen a lot of phones without hscsd.Eg : N70
b/w i am thinking of a phone at around 7k.Thinkink of stretchng my budget and going for 6233.
Req are 1.Killer looks,2.internet connectivity features.Mostly i need a phone to boost my image within my budget.
Edburg is offline
Old 24-04-2007, 10:02 AM   #11 (permalink)
Wire muncher!
^^^ not true. hscsd is a parallel technology of gprs. edge over hscsd is availalble in some countries. but here in india it doesn't make any difference.
anyways, 7k is far too less for the features u've mentioned. 6233 is a great phone but loses out in the looks dept.! for the price of 10k u can get k750i, great value for money as 6233 but again, looks wise it loses.
Old 24-04-2007, 10:26 AM   #12 (permalink)
Edburg's Avatar
ok my budget can be stretched to 9k but k750i lacks edge.
Also which is the cheapest s60 phone.Any other good models in my price range.
Edburg is offline
Old 24-04-2007, 10:37 AM   #13 (permalink)
krazyfrog
Posts: n/a
Cheapest S60 phone with EDGE is Nokia 6681. It could come in your budget.
Old 24-04-2007, 11:09 AM   #14 (permalink)
Edburg's Avatar
but my brother alreadyt has a 6680 phone so i wont buy the same thing
and as i would be going in for a high end mobile in 3 or 4 months,i need one with good resale value too.
Edburg is offline
Old 24-04-2007, 12:53 PM   #15 (permalink)
Tech.Masti's Avatar
You can consider Nokia E50...... price is around 10K
Tech.Masti is offline
Old 24-04-2007, 06:12 PM   #16 (permalink)
Google Bot
Pathik's Avatar
For internet speeds + multimedia usage get a 6233
For a symbian OS get a e50... it rox..
Pathik is offline
CELL PHONE WAR! HP Enters the Cell Phone Fray!!! Kiran.dks Technology News 14 11-05-2007 04:45 PM
Forget the cell phone, here comes the DELL phone! koolbluez Technology News 24 26-02-2007 11:44 PM
Which 1...mp3 player+cell phone (or) Wlkman Phone... deepakprabhakaran Mobiles and Tablets 8 20-10-2006 09:26 PM
Looking for a cell phone withing Rs. 12K. SE w300i, Moto RAZR V3i or any other phone mehulved Mobiles and Tablets 15 19-07-2006 01:27 PM
