Old 22-04-2007, 05:13 PM   #1 (permalink)
Default Connecting to yahoo messenger using Hutch GPRS , is it possible ?
Since hutch is preactivating GPRS connections for prepaid customers, and the browsing charges are like 10p for 10KB , i wanted to know if there is a way to connect to yahoo messenger and stay online.
I tried using meebo, but then the browser on my phone just doesnt allow me to enter the username/password in the respective fields since its a jsp i guess.
Is there any other way of doing so ?
cyrux is offline
Old 22-04-2007, 07:47 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Connecting to yahoo messenger using Hutch GPRS , is it possible ?
wap.yahoo.com
Pathik is offline
Old 22-04-2007, 08:05 PM   #3 (permalink)
Noobie Pro
alsiladka's Avatar
you could also use softwares to log into messenger, which is always a better bet than using wap messengers. And they dont use much of a trafic either.
For low data usage, you could use Mig33, supports Yahoo, MSN and AIM. And it is free.
But you should be having a JAVA enabled phone.
PS- BTW, if you decide to use Mig33, eventhough you can download and register for the service free of cost, if some other Mig33 member invites you to the service, he could get 1 Aus. Doller credit for that, which can be utilised to send cheap sms and make cheap calls. You shall get your 1$ credit on registering eitherways. So why not do so through an invitation
I am a Mig user, and need to make regular calls to USA, hence, it helps me to invite people. If you dont mind, you coud PM me your number and i could invite you to Mig?
www.twitter.com/alsiladka
alsiladka is offline
Old 22-04-2007, 08:11 PM   #4 (permalink)
Google Bot
Pathik's Avatar
mig works on gprs wit proxies?? Btw u could also try im+ or mobile yahoo.. Both r java softs.. But could give probs wit normal gprs..
Pathik is offline
Old 22-04-2007, 08:47 PM   #5 (permalink)
@alsiladka Pm sent
I use a Nokia 6681 which fully supports Java MIDP 2.0 .
So , shouldnt be any problems. Are they any specific changes that i need to make in my GPRS settings, do i need to use a proxy ?
@pathiks, visiting this section after some time and you are going great guns mate. You always ruled the mobile section
cyrux is offline
Old 23-04-2007, 09:38 AM   #6 (permalink)
Noobie Pro
alsiladka's Avatar
No you do not need any proxy or any changes. You can connect directly to mig33.
Old 23-04-2007, 11:51 AM   #7 (permalink)
You gave been GXified
gxsaurav's Avatar
Just use YMSG & you can connect to Yahoo messenger. I have written a tutorial for Web services on Mobile Phones which might help U.
about.me/gxsaurav
gxsaurav is offline
hutch gprs jatt Mobiles and Tablets 14 19-02-2007 01:29 AM
==Yahoo Messenger on Airtel GPRS= panacea_amc Mobiles and Tablets 9 28-12-2006 10:20 AM
Free GPRS in Hutch? Ishan Mobiles and Tablets 6 17-09-2006 07:01 PM
yahoo messenger not connecting,,is it any virus problem ? mkmkmk Software Q&A 1 05-05-2006 07:18 PM
Hutch GPRS - What Can I do with it? Scorpion QnA (read only) 12 18-01-2005 11:32 PM
