Old 22-04-2007, 01:29 PM   #1 (permalink)
Default How to format ?
Hi, Can anyone tellme how to format N72 ? it would be better if you mention both soft format and hard format.. i gotta format my phone.. thanks..
nav33n is offline
Old 22-04-2007, 01:36 PM   #2 (permalink)
krazyfrog
Posts: n/a
Default Re: How to format ?
Soft reset: *#7780#
Hard reset: *#7370#
Old 22-04-2007, 02:57 PM   #3 (permalink)
thanks! do you have any idea of taking a backup of messages in "my folder" ? because nokia phone browser doesnt show the messages stored under folders of "my folder" !
nav33n is offline
Old 22-04-2007, 05:37 PM   #4 (permalink)
mohitgiri's Avatar
back up ur all data using pc suit. after format restore data.
MOHIT GIRI GOSWAMI
mohitgiri is offline
Old 22-04-2007, 07:51 PM   #5 (permalink)
Google Bot
Pathik's Avatar
yea backup the whole fone memory to mem card or pc.. And better use the 3key format in n72.. Press *,green,3 wen rebooting
Pathik is offline
Old 22-04-2007, 08:05 PM   #6 (permalink)
krazyfrog
Posts: n/a
You can't just backup messages from one folder. You'll have to backup all the messages at once including those from Inbox, My folder, Mailbox, Draft, Sent and Outbox. Use pc suite for that.
Old 22-04-2007, 08:17 PM   #7 (permalink)
Google Bot
Pathik's Avatar
there s a option to backup the whole fone memory in os8.1 and 9.1 to the mem card.. That includes contacts,msgs,bkmks and evything
Pathik is offline
Suggest how to copy movies from CD format to DVD format? please help.its urgent tomdickharry QnA (read only) 2 17-10-2006 01:14 PM
CD/DVD RW Quick Format of Full Format techtronic Hardware Q&A 6 21-06-2006 12:45 PM
video file format to 3gp format converter beanstalk_230 Software Q&A 1 20-01-2006 01:12 AM
which is better quick format or full format cybermanas QnA (read only) 15 11-10-2005 08:26 PM
How to convert Real Audio format to MP3 or MP4 format ??? dkd903 Software Q&A 10 23-07-2005 11:38 AM
