Old 18-04-2007, 01:47 AM   #1 (permalink)
Cool Digital Camera
Hi,
I am planning to purchase the digital camera either sony dscw100 OR casio EX-Z1000.
Anybody will suggest me which model should I go for?
For Sony
http://www.sony.co.in/productdetails.do?prod_id=371
For Casio
http://casioindiacompany.com/cic/adm...l/news216.html
Plz help
Himanshu
Him007 is offline
Old 18-04-2007, 10:21 AM   #2 (permalink)
Welcome To The Jungle
sysfilez's Avatar
Default Re: Digital Camera
no comment on sony or casio. for camera i dont prefer these makes.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 19-04-2007, 03:58 PM   #3 (permalink)
plz help me
Him007 is offline
Old 19-04-2007, 04:10 PM   #4 (permalink)
krazyfrog
Posts: n/a
Go for Sony.
Old 19-04-2007, 04:35 PM   #5 (permalink)
:-o
aakash_mishra's Avatar
So what do you prefer????
www.amiable.in
aakash_mishra is offline
Old 19-04-2007, 04:38 PM   #6 (permalink)
yes that's a question..... Somebody is saying go for Sony, dnt know why?
Him007 is offline
Old 19-04-2007, 05:12 PM   #7 (permalink)
krazyfrog
Posts: n/a
Because 'somebody' thinks that Sony's digital cameras are better than those of Casio.
Old 19-04-2007, 11:59 PM   #8 (permalink)
www.indianangler.com
saikibryan's Avatar
same posts r prevalent all over the forum...
for optics nothing comes close to nikon or canon...
the two options you mentioned...yeah go for sony ofcourse
regards
when the going gets tough, the tough go.....fishing!!!
saikibryan is offline
Old 20-04-2007, 10:38 AM   #9 (permalink)
sysfilez's Avatar
canon and nikon for ur kind information.
sysfilez is offline
Old 20-04-2007, 08:21 PM   #10 (permalink)
gmanog's Avatar
^^ can you explain why? I think, this is a technology based forum, its better if you explain why you do not prefer sony and casio??
I have read in many reviews that sony is also one of the major camera manufacturers and also makes some very good models.
gmanog is offline
Old 20-04-2007, 08:54 PM   #11 (permalink)
prasad_den's Avatar
I've seen my friends using sony and casio.. And I find very little difference between them in terms of image quality, when set at the same MPs..!! So, as far as I'm concerned, go for one which has more features for the same price. Nothing's wrong with casio... the exilim series are among some of the good point & shoot cameras..!
In your case, I think I would choose the exilim... And one -ve in case of sony is the memory card format.. You gotta go for the expensive proprietary memory stick duo.. whereas the exilim supports SD cards..!
prasad_den is offline
Old 20-04-2007, 10:06 PM   #12 (permalink)
gmanog's Avatar
^^ Memory stick duo is also manufactured by many other good companies like scandisk, you can get them cheap. So that need not be treated as a reason for rejection the sony option.
If the starter of this tell the amount of money he is willing to spend for the camera and purpose, others can suggest a good camera on that basis.
gmanog is offline
Old 21-04-2007, 11:03 AM   #13 (permalink)
sysfilez's Avatar
y dont u google it and find it out urself. i just posted my opinion. i never said sony and casio are bad.
sysfilez is offline
Old 21-04-2007, 03:22 PM   #14 (permalink)
Yes you are right!!!!!!! thanks,,,,, but one problem that it supports only AVI format for video recoding not mpeg .
Him007 is offline
Old 24-04-2007, 03:13 PM   #15 (permalink)
any more suggestion?
Him007 is offline
Old 24-04-2007, 04:02 PM   #16 (permalink)
desh2s's Avatar
go for canon IXUS 900 Ti
its a great camera for beginer
desh2s is offline
Old 27-04-2007, 11:51 AM   #17 (permalink)
Ya you can go for SONY DSC W100.......
It is really a nice Digital camera.
It has power of 8 MP CCD. For that much high CCD sony use 1/1.8" Image sensor which help it to reduce Noice at high ISO Level. It also has high sensitivity upto ISO 1250 (target) & Sony's Clear Raw Noice reduction technology enbles W100 to take nice & smooth picture at high ISO in Low light condition.
For budget of 20K W100 is surely better deal than Nikon or canon.
It is true that in past Nikon & canon is better than Sony in camera line-up.
But this is not true for these days....
Sony had re-engineered the W series. Sony chalanges Nikon and canon in mid-range camera segment by launching T & N series of cameras.
parimal_xp2003 is offline
Old 27-04-2007, 01:11 PM   #18 (permalink)
csczero's Avatar
I always supported Canon for its rich photos ..........but u know CCD in my 3 years old canon camera is dead .....now i wont buy canon next time ........anyother should i go for ........I have used my friend's Panasonic its pathetic...
DELL 1500 Vostro , Playstation 3, LG LD460 42" , Nokia E5
csczero is offline
Old 27-04-2007, 02:22 PM   #19 (permalink)
I have just chk the sony website they have introduced more new models, like w80, w90 etc.... having the duble anti blur, face detection etc......
Should I go for this model or still casio one (bcz it seems all the same features are also there)....
Him007 is offline
Old 27-04-2007, 03:14 PM   #20 (permalink)
W80 & W90 are powered by Sony Bionz™ high-speed processing engine, which help you for continous shooting & shooting in low light condition. Sony Bionz™ high-speed processing engine is used in Alpha D-SLR professional Camera. W80/90 came with anti-blur solution which help you aginst hand-shaking & they having high sensitivity upto ISO3200. It use 1/2.5" Image sensor.
While W100 is powered by real image processor. It has 8MP CCD. The most significant difference is the size of Image sensor. W100 uses 1/1.8" Image sensor. And W100 support the ISO 80 as lowest sensitivity. While For W80/90 it is ISO 100.
Though the W80 & W90 can shoot at ISO 3200. It becomes useless as too much noice level at such high ISO. Thaugh the result is nice upto ISO 800.
You should know about all terms like ISO Sensitivity, Image sensor size, CCD & understand the functions of it to compare cameras.
But I can tell you that any of W100/90/80 is better than casio EX-Z100.
Old 28-04-2007, 05:05 PM   #21 (permalink)
thnaks parimal_xp2003.... Ok i will go for sony, but what ever u mentioned that all the feature are found in the casio, like processor speed,ccd, ISO etc....
Have u ever tested with Casio that model?
thanks
Him007 is offline
Old 29-04-2007, 07:49 AM   #22 (permalink)
Ya I have tasted.
I am not telling that it is bad.....
But Sony is better deal.
Service centers of Sony are also easily available.
If you still confused go in nice camera-store & try both cameras......... and let you eye and mind decide.
Old 29-04-2007, 04:12 PM   #23 (permalink)
Originally Posted by parimal_xp2003
Ya I have tasted.
Ok, once I will prchase the camera would let you know....
Him007 is offline
Best Digital Camera under 10k!! mananknl Cameras and camcorders 9 22-01-2007 10:49 PM
Digital Camera Thegame Cameras and camcorders 1 30-12-2006 01:46 AM
Digital Camera in 6 k tanmoy_rajguru2005 Cameras and camcorders 14 20-02-2006 11:41 PM
Which digital camera to buy... jay4u Cameras and camcorders 8 10-01-2006 11:00 PM
best digital camera available???????????? alaap_anujan Cameras and camcorders 2 14-11-2005 07:54 PM
