Old 17-04-2007, 07:12 PM   #1 (permalink)
Dreamweaver
Gigacore's Avatar
Smile Tips on Mobile Maintenance
Looking after your mobile helps to ensure it has a long and productive life. There are 8 easy maintenance tips to help you get the best out of your mobile phone. All of the points below should also apply to your battery, charger and any other accessories.
KEEP YOUR MOBILE:
Charged: Ensure your battery is fully charged, and then completely run it down before recharging. Recharging too early causes your battery to run out of power more quickly.
Secure: For security reasons, enable the PIN on your SIM Card and Phone-lock on your phone to avoid unauthorized used. These security checks will also be activated when the phone is power cycled. You can check with your carrier or the phone manual for the features and also for information on blocking your SIM card and phone IMEI number if the phone is stolen. For more information please see the Security Tips located on the AMTA Lost and Stolen website.
Protected: Make sure you use a keypad lock to lock your phone. Unplanned calls can cost a fortune and even though your phone may be in a safe place, such as in a bag, your phone will still get knocked around to a surprising degree. Rough treatment can damage electronic circuit boards so avoid dropping or unnecessarily shaking your phone.
Battery: Be safe with your batteries. Use only genuine batteries from your phone manufacturer and only buy from authorized dealers. Going for the cheap option of a counterfeit battery can be dangerous.
Clean: Don't use harsh detergents, cleaning solvents or harsh chemicals to clean your phone. Wipe only with a soft cloth.
Covered: a protective cover will help repel dust and dirt, and prevent scratches. Make sure the cover you choose is of good quality. Low quality covers with no air pockets can damage you phone by creating humidity inside the cover.
Storing your phone: Always store your phone in a dry place. Avoid rain, high humidity and liquids. All of these may contain minerals that could corrode the electronic circuits.
At the right temperature: To ensure a long life, keep your phone in a stable temperature. Avoid exposing your phone to liquid and/or exposing your phone to extreme temperature change from hot to cold and vice versa. This might create condensation and damage the phone.
Gigacore is offline
Old 17-04-2007, 07:54 PM   #2 (permalink)
Noobie Pro
alsiladka's Avatar
Default Re: Tips on Mobile Maintenance
Copied from net. I googled it, gave a link to a blog, althought the site is not working, i saw the cache. the matter was the same.
www.twitter.com/alsiladka
alsiladka is offline
Old 17-04-2007, 08:25 PM   #3 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
@Intel_Gigacore...post the source
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 17-04-2007, 10:57 PM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
Originally Posted by Intel_Gigacore
KEEP YOUR MOBILE:
plz do NOT do this! it will kill ur battery, if u are using one of the newer phones wid Li-ion/plolymer battery.
infra_red_dude is offline
Old 17-04-2007, 11:43 PM   #5 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
^^ u mean we should charge our phone before it completely goes out.
n00b forever...
~Phenom~ is offline
Old 18-04-2007, 12:13 AM   #6 (permalink)
Wire muncher!
yes, Li based batteries do not suffer from memory effect (only Ni-based battries do)... on the contrary theoretically Li-based batteries will deteriorate when fully discharged. so its a good idea to keep the battery fully charged.
Old 18-04-2007, 12:32 AM   #7 (permalink)
Google Bot
Pathik's Avatar
yep exactly li ion batteries dont hav the memory effect.. And in case of ni too that has to be done the 1st 2-3 times only
Pathik is offline
Tips and Tricks for avoiding Mobile Virus Gigacore Mobiles and Tablets 2 19-04-2007 07:47 PM
Maintenance of Server and Clients in a network sainit Networking 3 28-06-2006 02:15 PM
Bizzy's Guide to Good Hard Drive Maintenance bizzyboy QnA (read only) 3 29-12-2004 09:50 PM
