Old 15-04-2007, 02:22 PM   #1 (permalink)
Devrathnd
Posts: n/a
Default Mobile with 2 SIMS
Can anyone knows a mobile which has 2 slots for 2 SIMS so that i can use both my connection in one phone
or
Whether Nokia 3230 supports dual SIM so that i can use a double sim holder
please
Old 15-04-2007, 02:40 PM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: Mobile with 2 SIMS
thre's no cellphone wid inbuilt support for 2 sims.. and sim holder can be a bit bulky.. so its better if we test it ourselves whether it fits in the phone!
infra_red_dude is offline
Old 15-04-2007, 02:56 PM   #3 (permalink)
Tech.Masti's Avatar
Dont think that its possible to use 2 SIM at the same time, heard about such type of things lot (2 SIM in one phone) , but still cant found one person who using such thing can anyone briefly explain me what it actually is......
Tech.Masti is offline
Old 15-04-2007, 05:20 PM   #4 (permalink)
Google Bot
Pathik's Avatar
get the simx2 adapter.. Its quite slim.. And u need to just restart the fone and flick the sim holder to change the active sim
Pathik is offline
Old 15-04-2007, 09:58 PM   #5 (permalink)
Devrathnd
Posts: n/a
Whether i could use both the sims simultaneosly ie: recieve calls from both the connections or whether ony one sim can be used at a time and restarted to change to other connection
Old 15-04-2007, 10:02 PM   #6 (permalink)
Beneath The Eyelids
The Outsider's Avatar
i heard it voids the warranty, make sure you get it all sorted before you go for it.
The Outsider is offline
Old 15-04-2007, 10:27 PM   #7 (permalink)
gmanog's Avatar
There is no dual sim phone yet from the leading phone manufacturers. But its available, I saw an ad in newspaper, chennai, some time back. (some chinese make, I suppose)
see the following link, may help you.
http://www.fonefunshop.co.uk/dualsim/index.htm
http://shensun.manufacturer.globalso...-SIM-phone.htm
gmanog is offline
Old 16-04-2007, 12:10 AM   #8 (permalink)
Google Bot
Pathik's Avatar
nope only one sim can be active at a time.. Else there might be ambiguities..
Pathik is offline
Old 16-04-2007, 06:01 AM   #9 (permalink)
gmanog's Avatar
^^ No. see the link given by me. Dual sim mobiles are available. both the sims can be active at the same time.
gmanog is offline
Old 17-04-2007, 08:32 PM   #10 (permalink)
Tech.Masti's Avatar
^^dont think they are available in india, and price will be much higher... and maker is a unknown brand....
Old 17-04-2007, 09:35 PM   #11 (permalink)
gmanog's Avatar
^^ I have already told, there was an ad in the newspaper (The Hindu, chennai) some time back for these kind of dual sim phones. I have not seen that ad after that. It must be available in India.
gmanog is offline
Old 19-04-2007, 11:21 PM   #12 (permalink)
Hello Frnds now u can run two sims at the same time both of them are on in a mobile without any extra utility........
here is the mobile http://www.trendmobiles.co.uk/t500.html
mughal is offline
Old 19-04-2007, 11:34 PM   #13 (permalink)
:-o
aakash_mishra's Avatar
^^^ Is it available in India????
www.amiable.in
aakash_mishra is offline
Old 20-04-2007, 09:05 AM   #14 (permalink)
gdatuk's Avatar
yes it is..i saw it in a mobile expo in chennai
Twitter @cgiridhar
Moto Milestone | Rooted | Froyo | CM 6.1.0
AMD Phenom2 720 x3 BE | Gigabyte MA78G | WD 500Gb+Seagate 1TB ext | PSU Corsair vx450 | Corsair 2x2gb RAM | Bose Companion 5
gdatuk is offline
Sims 2 in Vista eggman Gamerz 7 27-02-2007 10:01 PM
2 Sims with 1 no sachinc Mobiles and Tablets 1 24-02-2006 07:42 PM
Sims 2 woo-hoo yrana2002 Gamerz 1 09-02-2006 04:39 PM
anyone sims 2 on their desk sanolution Gamerz 1 23-03-2005 08:57 PM
