Old 10-04-2007, 08:17 PM   #1 (permalink)
Exclamation N 80 Urgent help
Some body please tell me the MRP of N80 and whether I can install a 1 GB miniSD card in N 80.
Also latest quote Of N 73.
IN HOUSE GEEK!!!!!!!!!!!!!!!!!!!!
chirayu garg is offline
Old 10-04-2007, 09:01 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: N 80 Urgent help
n80 is around 18-19k.. And yes it supports upto 2gb.. N73 is abt 19k..
Pathik is offline
Old 10-04-2007, 10:21 PM   #3 (permalink)
The Techno Perv
yeah.. also n73 music edition is around 22.5 k
dtox is offline
Old 10-04-2007, 11:29 PM   #4 (permalink)
Google Bot
Pathik's Avatar
nope.. N73me is arnd 21.4k in mumbai
Pathik is offline
Old 11-04-2007, 09:00 PM   #5 (permalink)
Noobie Pro
alsiladka's Avatar
N73 is for 19k and N73ME is for 21k in Nagpur.
I do not know the cost of N80, but i would suggest N73ME ( Excellent Camera, Nice Music and Nice looks. Plus, not as bulky as N80).
www.twitter.com/alsiladka
alsiladka is offline
Old 11-04-2007, 11:07 PM   #6 (permalink)
Simpsons rox
IS there a 3.5mm stereo jack in n80 pls reply ASAP.
thx.
T.G. Praveen
A computer program does what you tell it to do, not what you want it to do.
Visit my site at www.praveen.co.nr
tgpraveen is offline
Old 11-04-2007, 11:21 PM   #7 (permalink)
krazyfrog
Posts: n/a
^^ No. Only via adaptor or selected headsets.
Old 12-04-2007, 12:24 AM   #8 (permalink)
Noobie Pro
alsiladka's Avatar
3.5 MM stereo jacks has been introduced in N95, for other phones, you can get the 3.5 mm stereo jacks through the Stereo headsets from nokia.
Old 12-04-2007, 12:32 AM   #9 (permalink)
Simpsons rox
will i be getting that headset with the n80 or do i hav to buy it separately.
ALSO
what is this whole chakkar of n80 and n80ie are they diff products?
what is the difference?
T.G. Praveen
Old 12-04-2007, 04:04 PM   #10 (permalink)
Noobie Pro
alsiladka's Avatar
I dont know about that headset being available in the package, but about N80 and N80IE,
IE stands for Intertnet Edition, and the only difference is that the firmware for IE is different, it allows you to download some applications through an Download Client, which is like a utility which includes links to some applications like Yahoo! Go etc. Also, it includes some utilities which allow for a better utilisation of the Internet, like direct uploading of Images to your Flick account etc.
If you do not use GPRS, then IE is not for you, and anyhow theres no other difference between them, so better you go to N80 only.
Old 12-04-2007, 04:12 PM   #11 (permalink)
Simpsons rox
so if i buy n80 then i hav to upgrade to ie firmware is that it?
or is n80 ie a diff prod to bought separately? if so what's it's price.
i am gonna gprs a lot so pls reply.
T.G. Praveen
Old 12-04-2007, 04:40 PM   #12 (permalink)
krazyfrog
Posts: n/a
You can easily upgrade to IE firmware as the differences between the two phones are only limited to software and not hardware. Prices are i think nearly identical.
Old 12-04-2007, 08:23 PM   #13 (permalink)
Noobie Pro
alsiladka's Avatar
Yup you can easily upgrade to the IE firmware, infact, Upgrading the Firmware to IE is officially supported by Nokia.
As far as i remember, N80 has been replaced by IE now, when you upgrade the firmware using NSU, it automatically upgrades itself to IE.
Old 12-04-2007, 10:53 PM   #14 (permalink)
Simpsons rox
ok thx guys.
T.G. Praveen
**urgent Help** kudos_sam Software Q&A 3 04-03-2007 11:46 AM
I need urgent help plz... digidude Software Q&A 9 17-10-2006 03:24 PM
Urgent Help !!! dreams QnA (read only) 7 06-02-2006 07:58 AM
