Old 06-04-2007, 11:25 AM   #1 (permalink)
nix
Senior Member
nix's Avatar
Default how is motorola W209? (entry level phone)
i saw its pic on metro booklet and its surprisingly cheap (rs 2.9k) i searched for reviews online but it seems to be a newly released entry level phone...
good features: 750 internal SMS
long battery life...etc...
so if anyone have it then pls give ur opinioon about it...coz i'm planning to buy a entry level phone...
is it better than c168?
nikhilspoliticalblog.wordpress.com- Common man bows to amitabh
nix is offline
Old 06-04-2007, 11:38 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: how is motorola W209? (entry level phone)
try nokia 6030 too..
Pathik is offline
Old 07-04-2007, 02:39 AM   #3 (permalink)
Tech.Masti's Avatar
naa, Moto increase some minor features but disable WAP & GPRS in this phone.... so i think C168 is better............
OR if you need good display, stereo radio, data cable support then Samsung X210 is also a good option, price Rs.3.6k
Tech.Masti is offline
Old 08-04-2007, 12:19 AM   #4 (permalink)
nix
Senior Member
nix's Avatar
i somehow dont like those flip-open type of phones...the ordinary one would be better..but the X210 seems to be good...so c'mon guys keep giving your feedback on which is the best entry level phone....
i've heard that the C168 has problems with text entry..ie text entry can be slow at times...
nix is offline
Old 08-04-2007, 02:09 AM   #5 (permalink)
Tech.Masti's Avatar
my 3 friends using Samsung X210, problem is TEXT entry is really slow and signal reception is not upto the standard, but if you are from city then you have no problem with signal reception.....
Entry Level Scanner-Printers xpabhi Peripherals 3 01-11-2006 11:46 PM
Need entry level cell phones tuxfan Mobiles and Tablets 20 01-09-2006 09:00 PM
Entry Level Scanner??? Urgent Aseem Nasnodkar Peripherals 4 05-05-2006 08:05 AM
Entry Level Graphic Card naveenpoddar Graphic cards 6 12-03-2005 02:24 PM
