Re: SE W300i
@gauravakaasid, in your budget, i'll suggest either SE W700i or Nokia 6233. K550i would be good too but since you want memory expansion upto 2gb, its currently not possible with K550i as it has Memory Stick Micro which is currently available at 1gb max and is very expensive. Also out of W700i and Nokia 6233, i'll recommend 6233 if you don't mind Nokia phones, as it has a QVGA display, great stereo loudspeakers, 2 mpix camera with VGA video recording, 3G/EDGE, and has a very comfortable keypad. Memory can be expanded upto 2gb at a very affordable cost as micro sd are fairly cheap.
