22-03-2007, 04:03 PM
Info needed abt Jad and Jar
Hi all..
I just wanna ask what are the .jar and .jad files. I know that they are java libraries. What I wanna know is that when I want to download any application for my phone, I see both files. which file should I download? what is the difference between them? I use k750i. For installing an application, should I copy both of the files? I usually do with the jar files. what does the jad file do?
22-03-2007, 04:26 PM
Security Exp
Re: Info needed abt Jad and Jar
wiki for Jar & Jad.. will get satifactory ans
We Love Once, And When We do We do it Well
22-03-2007, 04:28 PM
Google Bot
see the JAR files are the normal java installation files....
the JAD files contain the data abt the JAR files and are very small in size... open any JAD wit a text editor and u ll understand...
They contain data abt tha JAR like download location, size, installation method etc...
if u want to install something from a JAD in a cell then u ll need to hav GPRS...
24-03-2007, 12:54 PM
Get out of the confusion and download the .jad files as they are much smaller.
24-03-2007, 02:58 PM
Gangsta
Location: I come from the land of WARRIORS, land of 5 rivers, where the alcohol will make your liver quiver!!
24-03-2007, 03:22 PM
Still Shining!
Nokia phones generally use softwares and games in .jar format, while Samsung and Sony Ericcson accepts .jad files only.
Nokia N86 8MP
24-03-2007, 03:27 PM
Google Bot
all the cells use jad and jar both...
24-03-2007, 03:29 PM
Still Shining!
My Samsung set never allows to install jar files. Same is the case with my friend's SE set. But in a Nokia 3220 I have installed jar files. But it can't install .jad files.
Nokia N86 8MP
24-03-2007, 04:11 PM
In My Sony Ericsson, jar files are accepted (mine is k750i).
24-03-2007, 07:00 PM
yup both are accepted by my SE k790i phone
!!!!*Little Knowledge Is Dangerous*!!!!!
24-03-2007, 09:35 PM
Still Shining!
I had tried with a K508i. When I tried to install .jar files, it said unknown format.
Nokia N86 8MP
24-03-2007, 11:10 PM
Google Bot
in wichever se and nokia fones i ve seen both work... And shd work in any java enabled fone.. No doubt in it..
25-03-2007, 02:13 AM
let me clear the difference
jar - java archive files: these files are similar to zip files and rar files they contains compiled class files and resource used by the java aaplication. These file are single java executable files. JAR files are main file which contains the program. One can see the content of JAR file by open jar file winrar this will make your doubt clear about jar files
jad - java archive desriptor: jar files contains information for jar files like the version of app, filesize of jar file, main class name to be run, location of jar file etc. JAD file do not contain any program so you cannot run program by jad files alone. JAD maker is program which can make JAD files for JAR files.
Now some phone requires JAD and JAR files both while most mobile phone need JAR files. JAD file are used when you download java program from WAP. When you request for a JAR file it first gets the JAD file which contains the info about JAR files and the mobile phone then checks whether the program is supported by the handset or not without downloading the complete program.
visit my blog
www.anilsoni.wordpress.com:)
25-03-2007, 05:27 AM
Download JADMaker 1.15 JADMaker creates a JAD file for your . JAR Java Games : http://www.softpedia.com/get/Interne...JADMaker.shtml
jar and jad are the install files for java games right? ... The Jar file IS the game. You really don't even need the jad file for a java game.http://www.howardforums.com/archive/topic/551221-1.html
.jad & .jar... why two files? http://www.allaboutsymbian.com/forum...ead.php?t=4045
Get some java based apps in this site : http://www.getjar.com/software/
__________
BTW both .jar and .jad files work just fine on my SE K790i......
C2D E6600,Asus P5N32 e SLI,1GB 667mhz,Samsung 940BW,Zeb 8600GT,Seagate 250GB sata II,16x Sony(OEM) dvd RW,Zeb Anitibiotic & Platinum 500W,Microsoft desktop pro 700,bluetooth,Logitech MX Revolution
Reason: Automerged Doublepost
