Old 22-03-2007, 02:12 AM   #1 (permalink)
"The Gentleman"
vish786's Avatar
Wink antivirus for nokia 6600
could anyone suggest a site to download a free version of strong antivirus software for nokia 6600... it should be a good one worth installin...
vish786 is offline
Old 22-03-2007, 06:18 AM   #2 (permalink)
kumarmohit's Avatar
Post Re: antivirus for nokia 6600
AFAIK there is no need for antivirus in Symbian fones, unless u install each and everything u recieve from blutooth, just keep BT off and do not install, ANYTHING you did not ask for in the first place.
6600 has very low RAM, an AV will make it way slower.
If you are not convinced - A plea for sanity - http://3lib.ukonline.co.uk/viruses.htm
kumarmohit is offline
Old 22-03-2007, 08:00 AM   #3 (permalink)
Google Bot
Pathik's Avatar
Default Re: antivirus for nokia 6600
yea.. Fone viruses arent that advanced yet.. U can prevent/remove them easily.. No need of avs..
Pathik is offline
