| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#1 (permalink) |
mekalodu
will the speed be good? will it keep fluctuating? will voice chat or audio streaming be possible. thanks...
mekalodu |
#2 (permalink) |
Wise Old Crow
I dont know about EDGE data cards..but m using mob tht has edge.
The speeds are pretty descent between 10-15KBps. You will get good speeds in the morning. I can download a 7mb file in less than 10mins using d/l software. Its not that bad after all.
http://twitter.com/blueshift155 |
#5 (permalink) |
Posts: n/a
SE has two EDGE enabled PC cards. GC89 has EDGE and WLAN and supports data rate upto 54 kbps for WLAN and upto 85.6 kbps for GPRS. GC85 has EDGE and supports upto 247.4 kbps for EDGE. Both cards are Tri-band and support SMS. Actual network speed may depend on service provider.
#8 (permalink) |
mekalodu
i v heard abt the speed to be good but i wanted to know whether some one has actually used it and tried audio streaming with it..
thanks for ur replies
mekalodu |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
