Old 18-03-2007, 10:11 PM   #1 (permalink)
Cool Nokia Pc Suite
Hello Frnds. Nokia Pc Suite Dosnot work for me for my mobile Nokia 5200 with Usb Cable When i selected Nokia Mode In my Mobile But Nokia Pc Suite Dosnot Show it.
mughal is offline
Old 19-03-2007, 09:11 AM   #2 (permalink)
assasin's Avatar
Default Re: Nokia Pc Suite
try a different usb port of ur pc.
assasin is offline
Old 19-03-2007, 12:03 PM   #3 (permalink)
Google Bot
Pathik's Avatar
plug the fone in the cable 1st and then the cable in the usb port... also try different usb ports as assasin said..
Pathik is offline
Old 20-03-2007, 12:56 AM   #4 (permalink)
Gangsta
Josan's Avatar
Location: I come from the land of WARRIORS, land of 5 rivers, where the alcohol will make your liver quiver!!
Check weather you hav installed nokia suit correctly
Josan is offline
Old 20-03-2007, 01:08 AM   #5 (permalink)
You'r Born Free
int86's Avatar
Give a restart and wait some time. Sometime it solves problem.
If u have agenric(duplicate) Cable than U have to install Usb Driver prior to installing PC Suite
# Money, Beauty and Configration has no ends.
# Life is like game sometimes. Play it or loose it. But keep the spirit of game.
http://en.wikipedia.org/wiki/Right_to_Information_Act
int86 is offline
