Old 18-03-2007, 10:34 AM   #1 (permalink)
mdp
Default "Can Not authinticate the phone" Nokia 6600 Bluetooth connection error!!!
when i try to connect by phone Nokia 6600 to PC via bluetooth, it gives me error message"Can Not authinticate the phone."
I have tried many bluetooth ports' Widecomm', "bluesolile" etc. any body who have faced the same problem and came to solution please reply...
YOUR PLANS MAY FAIL, BUT DON'T FAIL TO PLAN...
mdp is offline
Old 18-03-2007, 01:50 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: "Can Not authinticate the phone" Nokia 6600 Bluetooth connection error!!!
can u pair it???
Pathik is offline
Old 18-03-2007, 03:40 PM   #3 (permalink)
Kiran.dks's Avatar
That's because you have not paired Mobile with your Computer. You need to Pair with a four digit number.
Kiran Kumar R
Kiran.dks is offline
Old 18-03-2007, 06:28 PM   #4 (permalink)
mdp
Boss, i have paired it by inserting both in mobile & pc .this is the step where problem is coming. after entering codes, it waits for about 10 seconds,and then gives the message.
a
mdp is offline
Old 19-03-2007, 07:27 PM   #5 (permalink)
rksingh's Avatar
Use the latest version Pc suit for 6600 not general version of pc suit.
rksingh is offline
Old 22-03-2007, 10:26 PM   #6 (permalink)
mdp
I have latest version of Nokia PC suite.it was Given in Digit CDs September & january issue..
by the way, do you use the same phone?
mdp is offline
Old 22-03-2007, 11:12 PM   #7 (permalink)
Kiran.dks's Avatar
a
Ok.. Try reverse pairing. Add the computer in mobile list. PC will ask for pin number and then enter the same in mobile.
If it's not working, then perform a reinstall of the Nokia PC Suite.
Kiran Kumar R
Old 24-03-2007, 05:17 PM   #8 (permalink)
rksingh's Avatar
Yes i use same phone. Use Pc suit for 6600 not this one.After installation of pc suit for 6600. My same problem is solved.Nokia pc suit 6.5 or later is not compatible for 6600
rksingh is offline
Old 24-03-2007, 07:34 PM   #9 (permalink)
Hell Sucks!!!
yeah, u wont be abl to do wid new suits use older ones wid 6600 support else not psbl
ashu_dps is offline
Old 24-03-2007, 08:49 PM   #10 (permalink)
Google Bot
Pathik's Avatar
use the pc suite that came in the cd u got wit it...
older fones dont work properly wit new versions..
Pathik is offline
Old 25-03-2007, 04:17 PM   #11 (permalink)
rksingh's Avatar
Pc suit for nokia 6600 has differant connection manager, Which supports serial port profile.
rksingh is offline
