Old 13-03-2007, 03:46 PM   #1 (permalink)
mohitgiri's Avatar
Default msgs from N70 to N73m
hi friends i have more then 1000 msgs in my n70 memory card. (e:\system\mail) i want to take it in my N73 or its memory card. what i need to do. plz help
MOHIT GIRI GOSWAMI
mohitgiri is offline
Old 13-03-2007, 05:08 PM   #2 (permalink)
Noobie Pro
alsiladka's Avatar
Default Re: msgs from N70 to N73m
Take the simple method.
Make a backup of e:\system\mail and paste them on your new memory card after using it once.
You will have all your messages on the New Mobile
www.twitter.com/alsiladka
alsiladka is offline
Old 13-03-2007, 06:03 PM   #3 (permalink)
Google Bot
Pathik's Avatar
do os9.1 fones use the same msging system.. If it doesnt work then save the msgs as notes/txt and send to n73
Pathik is offline
Old 13-03-2007, 08:33 PM   #4 (permalink)
Noobie Pro
alsiladka's Avatar
Or if you can simply use the Nokia Backup application from Nokia PC Suite.
It lets you backup and restore SMS between different phones.
