Old 08-03-2007, 10:17 PM   #1 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Default HELP to browse using opera in Airtel.
i have activated Mobile office.
if i browse using my phones inbuilt browser it shows it correctly
but error if i try to use with other application
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 08-03-2007, 10:58 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: HELP to browse using opera in Airtel.
wich apps u talkin abt?? and opera mini or opera mobile?? nd wat error??
Pathik is offline
Old 08-03-2007, 11:25 PM   #3 (permalink)
You'r Born Free
int86's Avatar
You will have to creat acess point in setting->configrations.
What phone u have. And whats the error message
# Money, Beauty and Configration has no ends.
# Life is like game sometimes. Play it or loose it. But keep the spirit of game.
http://en.wikipedia.org/wiki/Right_to_Information_Act
int86 is offline
Old 09-03-2007, 04:10 PM   #4 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
guyz i use k750i inbuilt browser is running fine but opera is not working
Old 09-03-2007, 09:38 PM   #5 (permalink)
You'r Born Free
int86's Avatar
Not know about se much. But u have to create a access point for other application. It is usually in profile or configration menu.
int86 is offline
Old 10-03-2007, 12:56 AM   #6 (permalink)
iChaitanya's Avatar
I am also using the same phone and i am also facing the same problem. Wapsites, websites are opeining in the phone's inbuilt browser. But applications like Opera Mini, Shozu, Widsets, etc. are not able to connect to the internet using mobile office. I think we need to get some other settings from the Cust. Care. and enter them manually.
APN is airtelgprs.com but still the apps are not able to get an internet connection..
Anyone knows the solution to this?
iChaitanya is offline
Old 10-03-2007, 01:08 AM   #7 (permalink)
You'r Born Free
int86's Avatar
Try making acess point in ur phone
int86 is offline
Old 10-03-2007, 01:55 PM   #8 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
i must be really dumb for not finding the settings for java
to run opera mini
go to menu>settings>connectivity>java settings>choose mobile office
try to connect now
Old 10-03-2007, 02:02 PM   #9 (permalink)
Google Bot
Pathik's Avatar
@max so finally did u get it or no??
Pathik is offline
Old 11-03-2007, 01:59 AM   #10 (permalink)
iChaitanya's Avatar
to run opera mini
try to connect now
ya man me too!
just found it in the morning!
Old 19-06-2007, 11:22 PM   #11 (permalink)
If you are looking for RSS reader check this out ...
If you look for a good (and free Rss software for your phone, try
SubliMobi Rss reader (http://www.sublimobi.com)
karmaresh15 is offline
Old 21-06-2007, 11:49 AM   #12 (permalink)
Google Bot
Pathik's Avatar
^^ what makes u think that we need an rss reader???
Pathik is offline
Old 29-06-2007, 12:49 PM   #13 (permalink)
Arrow Re: HELP to browse using opera in Airtel.
Hey, presuming u r using opera mobile 3.65, goto menu inside opera, choose settings and then u choose ur defult connection for gprs, eg Mobile Office as ur defult accesspoint,if required edit it or u can get the settings from ur service provider as a message and save it. In the user name space u can give ur cell no starting with +91. I think it will be solved. just trial and error man procedure man and hopefully u can connect to web using opera mini or opera 3.65.
rajarshi7 is offline
Old 29-06-2007, 02:20 PM   #14 (permalink)
a_k_s_h_a_y's Avatar
is mobile office availble with airtel karnataka prepaid ?? if so what's the cost per day ??
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is offline
